Title says it all, check my build thread. $13000 with the OZ's, $11000 with B6 S4 wheels. send me a message if interested, I will give you my phone number. I'm only selling it to a fellow enthusiast. I'm building a coupe Quattro.
Engine stock 2.7T
Daz tuned, 91 and E85
Frankenturbo F21's
Modified Frankenturbo inlets
SSAC down pipes, modefied with flex and 2 bolt flange
Fast intentions stage I and III, no cats, I switch out the center sections
044 pump
550 EV14 injectors
3bar map
034 85mm Hitachi maf
034 bi-pipes
034 carbon intake
034 spider hose
AWE side mounts with carbon shrouds
VagAutoWorks aka Daz 2.0T coil conversion
Transmission
JHM 1-2 collar
JHM carbon synchronizers
JHM centering spring
JHM Trio package
JHM cross rod
Fidanza flywheel
Ringer racing stage 4 clutch
Mounts
034 billet engine
034 snub and cage
034 billet trans
Apikol diff mount track
034 billet diff carrier with track bushings
JHM drive train stabilizer
Suspension/wheels
ST coilovers, I had purchased pss9's but returned to save for ohlins
034 front fully spherical upper control arms
034 rear fully spherical upper control arms
034 fully spherical rear tie rods
034 rear sway bar
034 subframe reinforcement kit
034 rear sway bar links
18in OZ superleggera lll
Brakes
Brembo 17Z up front
