Original AUTOBOSS V30 Elite Diagnose Scanner Update Online Support Multi-languages
Top 4 Reasons To Get AUTOBOSS Elite:
1. Original from Autoboss
2. Supported Languages: English, Spanish, French, Italian, German, Russian, Can Only Choose One Language (The default language is English, please tell us the language you want and pass serial number when you receive the package, we will get the language you want for you)
3. One Year Free Update Online ( After 1 year, Update Cost is 200usd, Please Refer to Autoboss V30/V30 Elite Security Card for One Year Online Update Global Version for the Details)
4. Cover more than 57 makers, 40,000 vehicle systems
Autoboss V30 Elite Super Scanner Function:
1. Quick test function to diagnose the complete vehicle
2. Cover more than 57 makes, 40,000 vehicle systems
3. More than just reading & clearing fault codes - goes far beyond and accesses the complete vehicle, including: drive line, chassis, body, and the networking /communication modules
4. Live data and graphing, performs actuations and adaptations
5. Electronic parking brake, Service light reset and much more
6. Cutting edge operation system: Windows CE
7. European & Asian vehicles with dealer-level power
8. Read & change ECU coding
9. Coding of the new control modules
10. Internet update function
11. Testing report saving function
12. Built-in Mini Printer
13. All necessary cables and adapters included
14. One universal connector for most vehicles, including all CAN vehicles
Autoboss V30 Elite Special Functions:
Self-Learn function enables the scanner to learn and save correct values for ECU live data parameters from a vehicle in good condition. For example, it will learn that on a Vauxhall Astra 1.7 diesel the coolant temperature sender should be reading between 0.5 to 4.5 V.
Comparison function can compare the learned values against the vehicle you are working on and highlight values which are out of range.
Record function enables users to record the vehicle data when testing the vehicle. And users can send the recorded data back to AUTOBOSS head office for analysis, which will help users solve problems faster.Navigation bar makes this tool more user-friendly.
Autoboss V30 Elite Covering car diagnostic tool latest and early car models of Asian, European, American and domestic.
-You can use 80%-90% functions of the original scanner on many cars.
-Supporting CAN- BUS diagnosis of Volkswagen / Audi, Ford, Mazda, Nissan, Hyundai / KIA.
-Built-in high / low speed CAN- BUS and single CAN- BUS.
-Making all CAN- BUS systems available with only one connector.
-Supporting 5 OBDII protocols and 9 modes.
-Nissan idle speed adaptation.
-Immobilization system generation III adaptation of Volkswagen.
The Equipment can be used as original one with most of cars. 80%-90% functions of the original equipment can be used in a few car models.
VW / Audi: All CAN- BUS system after 2005
GM: The testing function has covered 90% of the GM original equipment
Toyota: The actuation function is the same to the original equipment
Nissan: Covering 95% function of the original equipment
Honda: Only system selection is needed for diagnostic scanning
Hyundai / KIA: More than 90% function coverage of the original equipment
All systems of all car models are available
Opel: 17 models can be tested and the basic function makes no difference of the original equipment
Autoboss V30 Package List:
1pc x Autoboss V30 Elite Main unit
1pc x 8G SD CARD
1pc x OBDII-16
1pc x BMW-20
1pc x MARELLI-3
1pc x GM/DAEWOO-12
1pc x KIA-20
1pc x MAZDA-17
1pc x TOYOTA-17
1pc x TOYOTA-22
1pc x MIT-12+16
1pc x HONDA-3
1pc x AUDI-4
1pc x NISSAN-14
1pc x CITROEN-16C
1pc x Benz-14 Connector
1pc x FIAT-16
1pc x Benz-4 Connector
1pc x BENZ-38
1pc x Main Cable(2m)
1pc x Battery Cable
1pc x Cigarette Cable
2pc x FUSE 5A 30*6
4pc x FUSE 5A 20*5
1pc x DC Adapter
1pc x Power cable
1pc x SD Card Reader
2pc x Printing paper
List Date: 2/26/2016
For more info, click here to view the original listing: Original AUTOBOSS V30 Elite Diagnose Scanner Update Online Support Multi-languages
This item is no longer available.
