Results 1 to 40 of 54
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Question How much boost should be on my stock 99 AEB 1.8tqm have?
    I just installed the VDO boost gauge, and I only hit about 5 PSI in 2nd and 3rd gear, but I hit 6.5 in 4th and 5th gear, from what i've heard I'm suppose to have about 7-8?
    If I have a leak, where can I check? I already replaced the breathing system with the 034 breathing kit with new check valves, I did install a silicone TIP, but I made sure all the hoses were secure. I haven't cleaned my intercooler yet I doubt the previous owner did. I just got this car and its about 128 k now. But I have all the maintenance and the previous mechanic said there is oil in the intercooler, would that be the cause of loss of boost?
    Thank you!
    Apr 14 2014
    concord nc
    Quote Originally Posted by PsorianoPre99A4 View Post
    Thank you!
    Stock that's about normal. I run a forge boost controller on tip with forge diverter valve and f21 turbo. Stock tune. I run 10 lbs and the controller is in parallel with the n75 valve. Boost comes on very fast. Been running it for a year no issues. Max boost on aeb is around 7-8 lbs.
    Sep 01 2011
    Louisville Kentucky
    Approx 8psi is stock... I believe the actual spec is in Bar though. 12psi is the absolute ceiling on a stock ecu before it records an overboost situation and before the ecu begins imposing any "limp mode"...
    And thedownwardsprl, if you're running a stock tune on an F21 you're missing out on a world of benefit/performance. The f21 is a larger-than-k04 hybrid and flows a fair amount more than a k04-015.
    Oozed from a pustule of thought somewhere within the recesses of my mind...
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Quote Originally Posted by thedownwardsprl View Post
    Quote Originally Posted by SynapticA4TQM View Post
    Yea why the fuck you blow money on a bigger turbo and not be boosting it?
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Apr 14 2014
    concord nc
    I'm selling it and it still smokes the balls off of stock. Took back the injectors and such. 10 lbs of f21 is alot of air ya douche. Duty cycle maxed for stock fueling. May vary car to car. But aeb doesn't boost but 7-8 lbs stock on that pos k03. More air either way. It's a cheap 30 hp. And i like what I like. And are you going to tell the op to get 440 cc injectors turbo and tune for better boost. Boost isn't exactly more air. ... cfm is counted on by the turbo mapping, the tip, And of course manifold pressure and much other variables. Don't get hostile with me.
    Dec 13 2015
    PNW
    Yeah I plan on upgrading to the F21 with a stage tune with United Motorsport, with 440cc injectors.
    But I agree with King_, the point to have an upgraded turbo is to tune it to your car... Especially a F21..
    So anyone else agree that 5-6 on a stock AEB is normal? what factors would let me reach 7-8? I know getting a tune will increase boost, but anything else?
    Dec 13 2015
    PNW
    I don't think AEB has a "limp mode"
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    So how much you want for the setup?
    Sep 01 2011
    Louisville Kentucky
    No... 5-6 is low... A clean MAF, a properly adjusted throttle body, no boost or vacuum leaks, a heathy catalytic converter, no knocking/pinging/detonation, good quality gas, unclogged fuel filter/injectors/air filter are all things that need to be right for you to be running optimally. If you've never done anything with your turbo (or if nothing has been done with it by any previous owners) the turbocharger itself may be tired ... Ie bearings worn, oil passages may be coked, seals leaking, cracked exhaust housing or wastegate, deteriorated wastegate actuator spring are all things that could also be getting in the way of you making the boost you're supposed to.
    Dec 13 2015
    PNW
    Sell to me first if you don't want it :)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    No, it isn't. More than stock, yes. But a lot? No.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Sep 01 2011
    Louisville Kentucky
    Yes it does... It does not have the soft limp mode that the ATW or AWM have, but it does have limp mode, it just doesn't come on as easily as the others. For example... If you disconnect the plug to your n75, it will default to always open which will limit your boost to the wastegate spring pressure, which oe is approx 5 psi if it adjusted/set correctly.
    The stock ecu takes the MAF flow value and calculated a load value that in stock form relates nearly perfectly with the amount of boost created... It ISNT necessarily the amount of boost being created, but it does correlate very closely with it. It uses this value in reference to various maps in the ecu coding to determine the duty cycle for the n75. The n75 essentially works like a bleeder boost controller. A needle toggles opened/closed (which is the direct relation of its duty cycle). The higher the duty cycle the more often it is open and the more pressurized air it is allowing to reach the wastegate actuator. When that pressure reaches the actuators "cracking pressure" (which is the amount of pressure that is required to begin opening the wastegate) this is when air is being vented through to the exhaust portion of the turbine and out into the exhaust.
    In the event of certain DTC events, the ecu will set a duty cycle of 99% for the n75, resulting in all pressure being vented to the wastegate actuator, which then will result in no more than 5psi being created.
    Sep 01 2011
    Louisville Kentucky
    Quote Originally Posted by redline380 View Post
    Agreed entirely... An f21 is still smaller than a gtrs, gt28, or a t3-48... For 10psi to be substantially more airflow, you'd need to running a full frame t4 compressor housing, or something like a gt30, gt35 or larger.
    I do see and appreciate the perspective that 10psi is more from the larger turbo, but since the AEB ecu is using maps based on airflow for fueling delivery and timing, whether you run 10psi on an f21 or 5psi on a t70, it doesn't matter...
    Lastly, the OE MAF had a maximum of approx 190g/s of airflow that it is able to register. Additionally, based on how clean the element is, how healthy the element is that limit may be decreased, and quite simply how old it is, that maximum may be less than intended.
    Sep 01 2011
    Louisville Kentucky
    You are right... I hope you didn't think j was being hostile... It wasn't my intention.
    One thing to consider is that your duty cycle may be maxed, but unless you've have your injectors cleaned, or have installed new injector, they very easily may not be flowing as much fuel as they could/should be... As a result you may be hitting an artificial, premature limit... The stock injectors flow 240cc@4 bar.... If they have lost just 10% of their flow duty to being dirty, you're down to 216cc, and across all 4 that's nearly 100cc of fuel that your engine isn't getting.
    To the OP: For quite some time I've been running a unitronic 1+ tune on my 98 AEB. Logs have shown that I max out at 175g/s from approx 5k rpm to 7k rpm (+/- .5g/s) using a rough value of .8 x MAF flow, it's estimated that I'm running approx 218 crank hp. That's a 60hp increase above stock... Now the tune is written for a k03... I've ordered 550cc injectors, and a ko4 tune so that I can take full advantage of my equipment. Right now the car has near 230k miles, the engine I swapped last summer for one with 35k miles. I've also had to replace a number of vac lines and I've had to fix boost leaks... While frustrating I've ultimately been fine with having to do these repairs because it means refreshing things from their old tired shape and back to the way the engineers meant for the engine to run (boost and vacuum wise)... I bought the car 3.5 years ago with 196k miles and haven't looked back since. As long as you have taken care of (or know that the previous owners took care of the scheduled maintenance, you should be totally good to go with increasing boost.
    Apr 14 2014
    concord nc
    That is the tune i was on my way for but decided to go with a different car. I spent a lot of my time preparing the car for a stage 3 tune. Everything is new but money is getting tight. That's why im selling it.
    Sep 01 2011
    Louisville Kentucky
    I can totally appreciate that!
    Apr 14 2014
    concord nc
    Quote Originally Posted by MarcRogers View Post
    selling the car for 3500. This comes with the brand new coil overs
    Jan 18 2016
    PA
    Ahh I though you where just selling the turbo set up. I wish I had know of this before I bought mine would have paid 3500 in a heartbeat!
    Apr 14 2014
    concord nc
    yours for 3500
    Apr 14 2014
    concord nc
    Alot of money in maintenance and built to this car. Just don't have money or will to keep going
    Jan 18 2016
    PA
    Yea I'm in the process of building mine shit is not cheap
    Apr 14 2014
    concord nc
    Build*
    Dec 13 2015
    PNW
    Thanks for your advice, I am changing my fuel filter tomorrow, and I know my waste gate flapper does rattle a little on the deceleration, I have a K&N Filter with a eBay Silicone TIP, I put my hand on the compressor turbine and felt ZERO shaft play. I have a 710N TT DV with all new silicone vacuum hoses. I just passed emissions with my current stock cat and exhaust system, though I do have a eBay cat delete test pipe I plan on putting on. I buy Chevron 92 Octane only, brand new maf
    I haven't used an air compressor and tried it on my turbo actuator yet*
    Dec 13 2015
    PNW
    yours for 3500
    PM me the details, Is your F21 kit in there right now?
    Sep 01 2011
    Louisville Kentucky
    Sounds like you've got things well sorted and ready for some addition power
    Dec 13 2015
    PNW
    Would you Suggest that I replace my N75? I know the MAF was replaced with a bosch one. just 30k ago.
    Dec 13 2015
    PNW
    Thanks for the information, How are you liking your Unitronic Tune so far? how much torque you have?
    Sep 01 2011
    Louisville Kentucky
    It's a good tune... Just not made for the equipment I jave
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Wow. What a thread jack.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by richardodn View Post
    What is this supposed to mean?
    2000 S4- Working?
    Dec 03 2014
    United States
    Exactly what was said. Thread began with a member asking about how his stock car is supposed to behave and ended up being completely off topic about a different member's non-stock car. That's pretty much the definition of a thread jack.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Eh, it would be a thread jack if downward was just trying to sell his car randomly, but OP and him have exchanged posts:
    Definitely off-topic though, but that doesn't really matter as long as OP doesn't care
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Buys bigger turbo... does nothing with it... oh okay..
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Dec 13 2015
    PNW
    Anyone still have any factors of why my boost would be around 5-6psi at stock intervals? I realize my injectors could be dirty, so I just put some seafoam in the fuel tank. I also just changed the fuel filter yesterday, hoping that will work. Any other suggestions? I also forgot to mention, it does stay solid at 5-6 as i floor it, until I let go.
    Sep 01 2011
    Louisville Kentucky
    Seafood will destroy your filter and injectors ... But the omega-3 might helps their ability to stay focused... #ihearttypos!
    Dec 13 2015
    PNW
    Lol I thought I edited it, my bad
    Oct 09 2012
    Have you even done a boost leak test? just throw in a tune and do a test. and get boosting. I wouldn't worry about 1-2 psi unless your tuned.
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Dec 13 2015
    PNW
    Quote Originally Posted by King_ View Post
    Only test was installing my boost gauge. And I figured, I just didn't want to throw my stage 2 tune if I had a boost leak that I should take care of first, before putting more pressure on the engine.
    Oct 09 2012
    I would just throw the tune in, run it for awhile then do a boost leak test. More boost=more leaks. your not going to get the more leaks untill you add the more boost. no sence in testing twice.
    boostleak test diy: http://www.a4mods.com/index.php?page...boostleak.html
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Sep 01 2011
    Louisville Kentucky
    As far as worrying about boost leaks... It won't hurt to go ahead and replace any tubing that's not been replaced ... Ever?
    Like the boost hose going from the manifold to the top of the DV... The hoses between the compressor housing, the n75, and the wastegate... Of course inspect your boost pipes between the compressor outlet to the hard crossover pipe (crosses the front of the car taking charge air from the turbo to the smic) and the pipe from the crossover pipe to the smic for any brittleness, cracks, holes, etc.
    Just as problematic are vacuum leaks, these can be in any of the emissions hosing as well as some of the hoses that go from the manifold through the firewall, namely there is a little green cap that has broken on mine and created a vacuum leak...
    One test you can do is to spray carb cleaner or brake cleaner over vacuum lines, if you get an increase in rpm then you've found a vacuum leak...
    A way to find boost leaks is to take soapy water over boost lines, then you have two options... 1: use a tool to pressurize your system and look for bubbles, another option is to rev the engine good using the throttle body so that you get some boost built, and look for bubbles...
