Results 1 to 10 of 10
    Veteran Member Four Rings A U D I's Avatar
    Nov 13 2012
    Chicago
    B7 Carbon Fiber Rear Valance, sort of...
    Okay, So this valance can be from a Mercedes but is labeled as a B7 DTM. It may fit a DTM rear bumper but I don't know for sure on it. When fitted on a S-Line rear bumper it was only 1/4" wider from fitting into the cut out perfectly. If your interested and have a DTM bumper we can measure it to see about the fitment. If you have a S-Line bumper, you would be buying it knowing some modification is needed. I wanted to update this to cut out confusion on this piece since I do not have a DTM bumper to test it with.
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Price?
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings Hightekflytech's Avatar
    Sep 24 2013
    I.E. Cali
    Nice but the middle kinda throws me off
    Nov 13 2012
    Chicago
    Best Offer on it
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    Will this fit quad exhaust/DTM rear bumper?
    Nov 13 2012
    Chicago
    It is made for a quad tip because of the opening size and is marked DTM B7. I'm not sure what the fit difference is
    Jan 31 2016
    SoCaL (L.A. County / O.C.)
    If I may shed some light...
    That's a carbon fiber rear diffuser made specifically for a W209 CLK63 Black Series. Meant for a Mercedes Benz.
    The only other models that it will fit properly are other W209 CLK's.
    The part number at the top says... A / C 209 BS (translates into... W209 chassis, CLK63 Black Series model)
    Below are pictures to illustrate...
    This is the only Audi I've seen use this diffuser...
    That "B7 DTM" sticker is really throwing me off. I would think that the shape and fitment would be difficult to work with on a B7.
    Nov 13 2012
    Chicago
    I remember that one ! He did use a W209 CLK63 rear diffuser on his. Expensive diffuser also ! But not a B7, lol
    Jan 31 2016
    LoL. Yeah. Those diffusers aren't cheap.
    Nov 13 2012
    Chicago
    Thanks for the good eye on the label break down. I tried test fitting it on a S-Line bumper and it almost fit. It was about 1/4 wider on each side keeping it from fitting. Maybe only fitting to the DTM Audi bumper or only the CLK. Seems like with minimum effort it can be fitted.
