Results 1 to 9 of 9
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Weird gasping sound under WOT
    I noticed that under WOT I am hearing several quick short gasping sounds at peak boost. It almost sounds like an air leak near the intake and intake is gasping for short quick breathes of air. It doesn't happen when I'm off throttle only when on throttle and under high levels of boost.
    Any thoughts on what I might check?
    I haven't run a boost leak and there might be a tiny gap between test pipe and turbo exhaust but I cant tighten the test pipe on any further.
    Could it be my DV, boost leak, exhaust leak or N75?
    I have a stronger spring for my DV and shims. Looked at the intake and it seems tight. Tightened all my turbo bolts, checked IC hoses and searched for cracks. Nothing. Haven't run a boost leak test yet.
    If you have any insight please let me know, I have a feeling the boost leak test will solve it. But am worried it's some bolt on.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    May 08 2014
    CLFX, Denver
    Changed out my diverter valve. There was a blown o ring in it. Replaced with 710N. Problem seems to have disappeared.
    May 08 2014
    CLFX, Denver
    Problem still persists with 710n DV. Sound comes from near intake. I have built a boost leak tester and will try that asap. Please throw out any theories if you have them!
    May 08 2014
    CLFX, Denver
    No one cares but the turbo exhaust gasket was blown out. I replaced that with the oem like gasket that has a metal ring on the inside. It is made by felpro and I got it at Autozone for $7. I was at the dealer and their $26 gasket looks exactly the same. My boost leak tester piping wasn't quite the correct OD to fit the ID of my FT TIP. Building a new one ASAP to boost leak test as well. I'm hoping everything else is nice and tight.
    Apr 03 2016
    Up North
    Glad you solved it. For future reference if its a DV issue it will usually throw a code. My 1.8t did until I got my Forge replacement at least...
    May 08 2014
    CLFX, Denver
    Quote Originally Posted by Human Garbage View Post
    I don't think that actually fixed it. It may be the foam filter on my Carbonio CAI. I still need to boost leak test as well. I haven't been able to stand on the pedal yet since replacing the gasket.
    Apr 03 2016
    Up North
    Sorry to hear that man. A gasping sound does seem to indicate an intake side leak though, boost side is more of a hissing sound. Good luck!
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    Quote Originally Posted by HUFset View Post
    Keep posting updates. I'm watching your thread.
    Also maybe run through all your check valves and make sure they flow one way and are blocked the other. I'm thinking on this though to try and help
    May 08 2014
    CLFX, Denver
    It was a broken check valve near the intake.
