Results 1 to 15 of 15
    Oct 20 2014
    United States
    Painted MMI trim piece
    I'm posting this after seeing how the rs4 surround is piano black. My question is if anyone has ever done this if they could post pics or even if you haven't done it, could you post some tips on what you would recommend to use for paint?
    The reason I am looking to do this is because I currently am building my airlift v2 controller into one of the center air vents and therefore will need to fill in the gaps of the rest of the vent (the controller doesn't block the whole vent) to make it look clean. After doing so I will need to paint it but obviously will never get a paint to match the silver or anything else in the car perfectly. When I paint this, I would prefer to paint the surround as well so that it will match.
    Please leave some tips or helpful advice if you have any!
    Thanks!!
    Current: 2013 Audi A4
    Sold:
    2015 F83 BMW M4 OEM + (Lots done but not too much lol)
    2014 Phatom Black S4
    Mods:| Unitronic Stage 2 | 19x10 Rotiform Ind-T Chrome stepped lip with brushed Aluminum faces | Avery "Dark Grey Gloss" vinyl | Airlift Performance Bags | Autopilot v2 | 5% tint, APR Stage I + II Intake | Carbon Fiber J-Codes | AK | USS system | Miesterwerk SS | Deval Front Lip | AWE Non-Res DP's | AWE Track Exhaust |
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Many wrap them in vinyl, but some members have painted them. I haven't done either personally, but from the reading I have done, be sure to prep the surround really well prior to painting it or you risk chips/flakes.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 14 2012
    Empty...for now...
    SE PA
    Something tells me it will be difficult to achieve that high-gloss piano black look with a DIY at home job. I would recommend having it done by a professional shop.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I did it on my 2010. I have posted pictures in the distant past, but I could never get really good ones due to lighting issues. I used Rustoleum Universal paint, but I used Satin Black instead of gloss. I actually taped off the panel and sprayed it in place. I was afraid of damageing the panels during the removal. One of the issues of painting the surround black is it shows the dust much more. Also everyone seems to use Gloss black. IMHO, Satin black is a much better match to all the other black surfaces in the interior. Much easier to get a professional;looking finish with satin vs gloss. I only wiped the pieces with alcohol prior to painting and had no chipping issues. Good Luck
    Feb 13 2004
    Silicon Valley, CA
    Check my build thread. Did it about 6 years ago and still looks great
    Kevin - Moderator, Audizine
    Jan 28 2013
    I did that, if this is the part you are talking about. I think it looks much better than the silver. FYI, you can have a body shop paint it for ya the Audi paint code is V58 Black High Gloss.
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    I bet if it came from the factory in piano black, you guys would paint it flat silver.
    CEO and General Manager of the AZ Pedal Responce Team
    Aug 25 2008
    Boston, MA
    Jan 28 2013
    Quote Originally Posted by Elliott View Post
    Have you seen the difference between the silver and the gloss black? The Silver doesn't look as good as the black IMHO, so I changed it. But, continue to be snide.
    Quote Originally Posted by dzasta View Post
    You mean the Plasti-dip one? Not sure why someone would do that, but to each there own.
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    I second the vinyls wrap. I used. 3M flat black and it matches the flat black of the console perfectly IMHO. And it's entirely removable if you, or the next owner, wants.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    Not light the complete black look...i think the silver is better, but to each their own.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Lololol
    2021 Audi S4, P34 Intake
    Jun 08 2005
    Lexus RX 350
    SE, PA
    The problem with the silver is that it doesn't match anything else in the interior if you have CF , SS or wood and alum trim. Its OK if you have the Alum trim
    Oct 20 2014
    United States
    Thank you guys! I'd like to stay away from vinyl wrapping it Bc I think paint would be much better. And yeah never would I rustoleum my Audi interior haha. Thank you too for whoever posted the paint code!
    Sold:
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Quote Originally Posted by Lamprey View Post
    I chose to use plasti dip because it's easily reversible and it matches the black plastic trim perfectly.
    Fwiw, "To each their own" is the saying...
    Will
