Results 1 to 17 of 17
    Jan 26 2014
    66 Shelby Cobra
    Kansas City, MO
    Brake squeal when cold - 2012 S4
    Is there anything that can be done (outside of turning my stereo up) to fix the annoying brake squeal when it's cold out? It does not go away after driving and I am annoyed to hear it at every stoplight I pull up to.
    I took it to the dealer last year and they lubed up the slider pins... Did not really seem to help.
    Mar 11 2015
    DE
    Change your pads lol. The OEM pads are super squeaky in the cold, give off a lot of dust but have great bite. Trade for some Akebonos and you'll get rid of the squeak, most dust but you'll give up that initial bite.
    2013 P+ | DSG | SD | BO | Carbon Atlas | MMI/NAV | Nappa Leather | Supercharged Badges
    AWE Touring with Res DP Exhaust | H&R Spacers | Passport Escort 9500ix + Blendmount | Weathertech Liners | AWE S-FLO | H&R Sport Springs | EC Alu Kreuz | Forgestar CF10 | EPL Stage 2
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    I think there is a TSB (maybe) about getting the less aggressive brakes installed. I believe I read about that on this forum. But yeah, other than that, they are gonna squeal. Or, you could just install less aggressive (I.e less metallic) brake pads. It doesn't bother me.
    Established Member Two Rings TheLetterJay's Avatar
    Sep 26 2015
    ATL | NYC
    It could be the brake pads. I've had the fronts on my 14' S4 replaced with Akebono Euro Ceramics and not a peep since.......not as grabby as OEM, but gets the job done for me.
    Sent from my XT1575 using Tapatalk
    2018
    034 Mounts, Inserts, Rear Sway, Front Strut Brace | ECS Intake, FMIC | ABT H.A.S. | Forgestar
    Gone
    2014 S-Tronic
    Eurocode Alu Kreuz | CR-15 | 034Motorsport Transmission Mount, Strut Mounts, Rear Subframe Inserts | Solo-Werks | ECS Luft-Technik Intake, Rear Diff Mount Inserts
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    There is no permanant fix for this other than replacing the pads. Audi is aware of the issue but continues to put on a brake pad with a compond that is prone to squealing. In fact, they have produced a brochure to give to owner who complain to explain why they use this compound. Do yourself a favor, replace the pads with Ceramic pads, as Eggroolz4U suggested. The lack of brake dust is reason enough by itself. BTW, I have Stoptech Ceramics front and rear.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by TheLetterJay View Post
    I agree with this, although I went with Wearever Gold pads up front and Akebono Euro Ceramics in the rear. My feeling is the same - less initial bite than OEM pads but I have gotten used to it. The vast reduction in brake dust accumulation on my wheels is fantastic. I haven't washed my wheels in over 3 weeks, which includes miles driven in the snow, rain and muddy east coast ski resort parking lots, and they look as clean as they would look after less than 1 week when using the OEM pads. And to the OP's question, I have not heard them make a sound under any conditions.
    SOLD 2015 Daytona Gray S4
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    OP, I had this ongoing issue with my B8.5 S4. My brakes started squeaking only in the cold but slowly started squeaking All The Damn time. It drove me Nuts! Took it to Audi for a brake checkup and they told me brakes were fine and that the Tech had lubricated contact areas. Driving home coming from the dealership I heard the damn sqeak. Point of the story, OEM brake pads are great at stopping but are noisy and dirty since they are Semi- Metallic. Finally had it and ended up ordering a set of Akebono Ceramics Pads and I have virtually No dust on my wheels and more importantly there dead silent.
    2014 Brilliant Black | 034 Motorsports filter | 034 DSG Tune | Black Fine Nappa Leather | Prestige | 7 Speed S-Stronic | Apr tune | Roc Euro Intake | X pipe Exhaust | Akebono Brake Pads | Deval CF Rear Diffuser | ECS Spacer Flush kit 10F 12.5R |
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Normal condition.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Yeah mine squeal like a pig when its super cold... One thing I do is I wash the dust out of the pad area and it helps a bit but as soon as you do some driving that bad boy is back to crying out... Love the stopping power.. Hate the break dust and squeals! Bring on spring!
    Veteran Member Four Rings Thurston's Avatar
    Apr 27 2015
    canada
    it's really quite humiliating when it happens.. it is unbearably loud and just really q unacceptable. Audi replaced my pads (with over 50% life remaining) for free and supposedly polished the rotors but I honestly don't believe they did sh*t w/ the rotors which is fine I was happy to get new pads and it has at least temporarily gone away. they put some tsb on my receipt but i don't remember which one- i can look for it if you can't find the tsb
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    Same issue here...just gotten used to it. Figure when the pads are due I will replace with the Akenobos and call it a day.
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    2016 S6
    Feb 09 2015
    2001 A4 2.8 Quattro
    Anybody experiencing Brake Squeal should just get Akebono pads instead of replacing the stock pads with identical OEM pads. Cost me literally 300bucka for pads+ install at a local euro shop. Why keep embarrassing yourself when you can make the squeals go away no matter the temperature and not have to clean your wheels in weeks?! Lol no brainer guys
    Mar 05 2014
    2020 SQ5
    PDX
    Happened on my old 2013 S4 at about 10K miles. Wouldn't go away no matter what the dealer told me to do "Deglaze".... Was going to replace with Ceramic pads, but ended up trading it in to get a 2016. Squeal gone for now! /kappa
    Mar 21 2015
    +1 on that. Me too.
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    I like the Akebone, like others said not as much bite, but MUCH less brake dust and no squeal.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Established Member Two Rings ZGskibum's Avatar
    Jan 17 2016
    Aspen, CO
    If you brake hard every once in a while it'll temporarily burn off whatever makes the squeak. If you don't regularly drive in a spirited manner that gets your bakes hot, just do a 50-0 brake check once or twice per drive and you'll be fine. There is actually an official Audi brake-squeal TSB for the Q5 that instructs the techs to just do 3 50-0 brake checks in a row and then give the car back to the owner.
    Added benefit: you get to wear down your rotors faster, at which point you can tell your wife you HAD to replace the brakes. And gee wiz, it only makes sense to replace them with the biggest Brembos that'll fit inside your wheels....
    2011 S4 6MT Sport Diff | Ibis w/ Black Optics
    APR Stg II+ | AMS Cooling | AWE Touring - Res DPs | Roc Euro Intake | Sachs X-Tend Clutch w/ USP SS Line & Lutz (OEM) FW | Stoptech ST-60 355 BBK w/ SS Lines | H&R OE Springs | Bilstein B8 Shocks/Struts | CR-15 | H&R Rear Sway | Alu Kreuz | 034 Trans/Engine/Diff./Strut Mounts | BC Forged EH 307 19x9 ET 40 (Summer - Michelin PS4) | VMR V810 19x9.5 ET 40 (Winter - Pirelli Sottozero) | ECS Shortshifter | P3
