Results 1 to 11 of 11
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Question Seafoam in the Crankcase ok???
    I've heard mix reviews over the forums, just want to be clear if its ok to put some in my crankcase right before an Oil change? I was suggested to drive around 100 miles, than empty it. Has anyone done this? Also good for vacuum lines and the fuel tank?
    Senior Member Three Rings bmos's Avatar
    Apr 29 2014
    1973 BMW 3.0S Bavaria
    Maine
    You're better off using AutoRX.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I would put fuel system treatment in the gas tank.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    AutoRx x2
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I did both of these things 60-70k ago when I first got my car. Never any issues related to it but I've changed turbos multiple times since then.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Do you have sludge issues? If not, why?
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Amsoil engine/trans flush. Its a detergent with no aggressive chemicals. I use it once a year to keep my Audi sludge free on top of the Amsoil 5w40 Euro/turbo synthetic oil.
    01 1.8T | B6 Sport Wheels | Forge diverter valve | A8/TT Front Brakes/SS lines | 034 HFC & Milltek Resonated CB | APR TIP & Intake |
    Dec 13 2015
    PNW
    Quote Originally Posted by SN95Audi87 View Post
    Where could I find an amsoil dealer? Or cheaper amsoil?
    Dec 13 2015
    PNW
    Quote Originally Posted by AudiSport12 View Post
    My oil was pretty black when I first changed it, right now I changed its been using ow40 mobile 1 with a big mann filter.
    I was debating on switching to T6, but while doing that I was seeing what anyone of you would do, or have any product you suggest.
    Thank you
    Oct 10 2013
    State College PA
    When oil is black it means it's working and doing its job. It should be getting dark.
    Apr 26 2010
    North Jersey
    Quote Originally Posted by PsorianoPre99A4 View Post
    I'm not a dealer but I am preferred customer. It's only 20.00 a year for all the discounts. It's great.
    Also, the benefits of Amsoil 5w40 oil will push the life of 1.8T to the max. These engines break down the weight of the oil through rigorous heat, and Amsoil 5w40 is tough enough to with stand it.
    I can literally see my oil temp gauge go from 210 degrees to about 170-180 after a spirited run right when I get off the highway idling at a red light. Superior stuff!
    Also note that Amsoil flush removes engine deposits off the oil cooler so it return it runs cooler. Just my experience.
