Results 1 to 8 of 8
    Sep 16 2012
    canada
    fuel pressure gauge question
    Having some sporadic long cranking start issues. I'd like to start with testing fuel pressure testing and would like to know what others have done for fuel pressure gauge install and what size of fittings are needed to splice into line before fuel rail? Thank you for any help.
    Sep 16 2012
    canada
    Anyone?
    May 16 2008
    WA
    Is the long crank happening under certain conditions, such as sitting for a long time?
    I haven't looked at the fuel rails in a while, but i would think you just splice into the return hose:
    Sep 16 2012
    canada
    Generally yes. The longer it is sitting the longer it cranks. The f.p.r is fine. Thinking clogged open injector or old plastic feed line leaking in tank.. the c.p.s is not the issue.
    Senior Member Two Rings Quattro_The_Dog's Avatar
    Mar 03 2014
    sports gear
    The Woods, CA & WA
    Probably the check valve in your pump or regulator leak down.
    Stage 3+ S4 28 PSI daily driven
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    I bought a fuel injection test kit from Harbor Freight and while it's not a permanent addition to the engine bay it did include every adapter I could imagine and it works.
    Sep 16 2012
    canada
    Update:
    I Found the pressure loss at fuel filter. Fuel Line has small Crack and leaks where it attaches to bottom of filter.
    Does someone sell those short lines from fuel tank lid to filter??
    Oct 27 2011
    TOYS
    Philly Suburbs
    https://www.ecstuning.com/Audi-B5_S4...ne/Fuel/Lines/
    Quote Originally Posted by getslideways View Post
    And the fuel pressure gauge needs to be place between the fuel pump and the FPR, as close to the fuel rails as possible. If you place the gauge after the FPR in the return line, you wont be reading the fuel pressure that the injectors see.
