Originally Posted by
LightningLou
Lots of the oil comes through that line going to the f-hose hence why it's deleted. Contemplating a catch can myself right now, just need to figure out a good solution with the 034 spider hose I'm running
True. I just now realized the function of the all the components after going through the self study again..
When there is vacuum in the intake mani, the air distributor directs flow through the f hose using pcv valve, when there is charge pressure in the mani, blow by is routed into the y pipe, cylinder heads are vented into the air distributor.
Ideally I would like my set up to work with all the oem components intact, and without hindering the already old/out dated system. My main goal is to filter as much oil out of the blow by as I can..
I feel like there may be some issues with deleting the f hose, I know it's a thing people do without issue, but without converting to the newer style system I would opt for just upgrading the hose.. because you lose a source of suction(vaccum?) from the pcv when the intake mani sees vacuum. Which may not allow the crack case to vent properly under certain circumstances.. I'm assuming this could create a back up in the flow and possibly create issues with too much pressure in the cylinder heads.
