We typically recommend doing the adjustable upper arms depending on what type of drop the customer is looking for and what kind of mileage the car has on it. In your case the B12 kit isn't too drastic, it is on par drop wise with the H&R OE sport spring and like jran6 mentioned. You will be on the high end of spec for camber, lower mileage cars can be a bit less and higher mileage cars can be higher than that depending how the car was driven and where it was driven. The bushings in the control arm cause more camber as they wear. With that being said, we recommend them with setups with drop lower than the B12 or H&R OE sport are going to get you especially on cars that are getting up there in miles, it makes sense to do a control arm replacement while the assembly is out and being aligned. But it definitely adds quite a bit of cost on top, so it might not be needed for your application. Food for thought though.
If you have any questions, we have installed countless suspensions on these cars and installed upper arms on probably half of these cars.
Thanks,
Greg
