Results 1 to 13 of 13
Thread: Simple question
    May 30 2015
    2012 Ford Fusion (wife's car)
    Wellman,Tx
    Simple question
    Hey guys
    I was looking for either a test pipe or HFC due to my cat potentially being shot.
    Do I need a tune to run either one?
    I know I could use one for more gains.
    Will either one kill the engine?
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    I know you don't need a tune to run them, though they give you (slightly) more gains if you do get a tune afaik. As for hurting your engine, I've never heard of that happening and plenty guys around here run both setups, so I think you'll be fine!
    2007 Porsche Cayman | 5MT
    Feb 13 2004
    Silicon Valley, CA
    Complex Answer
    Yes and no.
    No, you don't need a tune, you will be fine and your engine will be fine, BUT you will have a check engine light for your second O2 sensor.
    Now, the second O2 sensor just tells the car how efficient your catalyst is, it does NOT change your A/F mixture or anything else.
    You can get rid of the CEL in one of three ways.
    1. get a spacer to hopefully move the O2 sensor out of the stream enough to trick it. Mixed results
    2. get a spacer with catalyst in it to move the O2 sensor out of the stream and have some catalyst to trick it. Better results than 1, but still mixed.
    3. get a "stage 2" tune which is the same as a stage 1, but codes out the O2 sensor so you never have a CEL. Works 100% and has the benefit of the extra power of a stage 1 tune.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by Stubek View Post
    Yes and no.
    </thread>...
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    May 30 2015
    Wellman,Tx
    Thanks guys
    I was reading a lot of mixed info.
    What about the performance of the car?
    Any ill effects. Ie running like crap, etc
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by fhh02a View Post
    Thanks guys
    Nope. Here is what I observed:
    1. Faster turbo spool
    2. Louder exhaust (maybe due to my exhaust leak)
    3. MOAR POWAA! (jk I did not notice a difference with just the test pipe except the faster spool but is needed for my stage 2 JHM tune (when 93 is released).
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    Yes and no.
    #3 is not true with a JHM tune. I am Stage 2 and have a CEL pop up regularly for my 2nd O2 sensor. Otherwise I agree with Stubek on these points.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    keep in mind that eliminating the cat is a violation of federal and probably TX state law. You would become a polluting outlaw!!!!
    May 30 2015
    Wellman,Tx
    where i live, there are no emission laws.. well no testing....
    so as the old saying goes " one less prius"
    Deactivated Three Rings
    Dec 30 2014
    86 Toyota Pick-up
    Birmingham, AL USA
    Would a HFC require a spacer?
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Brillo View Post
    And .....lol
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Quote Originally Posted by papadelogan View Post
    I have stage 2 and a 02 spacer for the rear and it does the trick. No CEL ever. I was stage 1 with the spacer as well and no CEL ever.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Feb 13 2004
    Silicon Valley, CA
    Quote Originally Posted by tater5387 View Post
    Read my post above
