Results 1 to 13 of 13
    Active Member Two Rings squintsy's Avatar
    Feb 25 2015
    B6 A4 3.0 6MT Avant-Daily, B6 A4 1.8T Tip Avant- project
    Indiana, USA
    no boost, then boost.... wtf
    a few weeks ago, while merging onto the interstate i lost all boost shifting into 4th. I didnt have boost the rest of the way to work. left for lunch and had boost again... figured maybe the DV was sticking or something cause the same thing kept happening. drive for a while and i would lose boost under wot. i ordered a new DV (007) and the car flies through gears. drove fine for a day and now im back to the same thing. could the WG be sticking or something? im lost
    Established Member Two Rings StriktlyAudi333's Avatar
    Jul 20 2015
    Mesa, AZ 85207
    Check the Forge. I had a 007 and had to clean it all the time. I typically would clean it ever oil change (4500 miles for me) and then I'd lube it extremely lightly with ATF also, do you have a B6? Cuz I've literally seen over 50% of modified audis with theirs installed sideways.
    Feb 25 2015
    Indiana, USA
    i do have a b6 i put the 007 in there the exact same way as the oem was in there. also should the DV be sticking after a day of use??
    Jul 20 2015
    Mesa, AZ 85207
    If you put it in the same way as the DV then it's possible backwards. The 007 goes in straight up and down with the horn facing the front of the car and the small vacuum hose that is connected to the top adjustment screw, should be pointed up at the top with the hose coming straight up and then across the TB cover
    Jul 20 2015
    Mesa, AZ 85207
    And yes it's possible mine did that same exact thing. Just unscrew the whole assembly and pull it apart. Use CRC valve cleaner and it's very simply put together just pay attention to how the spring is inserted and you'll have no issues putting it back together
    Feb 25 2015
    Indiana, USA
    awesome thank you!! i will give the swapping it around a go and see what happens.
    Jul 20 2015
    Mesa, AZ 85207
    How'd it turn out?
    Feb 25 2015
    Indiana, USA
    didnt get it swapped, got distracted putting in the new rear sway bar xD plan on flipping it around tomorrow or Wednesday though. might snow here again after 70 degrees yesterday!! horse shit.
    Jul 20 2015
    Mesa, AZ 85207
    Where the hell do you live! That's some serious weather changes lol. Here where I live it's already almost 90..
    Feb 25 2015
    Indiana, USA
    central indiana :/ it was actually warm enough that it was rain though.
    Feb 25 2015
    Indiana, USA
    okay, sorry for the lack of response. I flipped the DV around and the problem continued so i ordered a boost gauge and installed it so i would know exactly what im dealing with vac/boost wise. everything seems good at idle, -20, boost however...... i will spike up to 15 and taper back down to 9-10, then it will just dump off and cap out at 2-3lbs.... from other threads this sounds like it could be the n75 valve.... im gonna go ahead and order/replace it unless anybody has any other ideas as to what it could be. thanks!!
    Deactivated Two Rings
    Dec 02 2015
    Quote Originally Posted by squintsy View Post
    Also check the lines from the wastegate actuator to the N75, I had boost problems and because it was dark and the hoses are black I overlooked a cut hose many times before finally finding it.
    Feb 25 2015
    Indiana, USA
    i will give it a look over, thanks for the tip
