Results 1 to 9 of 9
    Apr 02 2013
    above top secret
    How to verify a good crankcase pressure?
    I think I just wasted $50 for a replacement of the UFO PCV valve, the PCV valve under the intake manifold as well as the T-connector. I'm currently having a slight oil leak but would like to fix any potential clogging in the crankcase system prior to replacing any seals or gaskets.
    So my car had 150K miles. What i noticed before was that the oil cap was "dancing", and air what "puffing" out of the oil cap hole. I checked the SJP and it was ok. Then after replacing both PCV I noticed that the oil cap is still dancing. This is contrary to some of the youtube videos that shows that there should be vacuum in it when tested using a rubber glove.
    Can I have an opinion on this please?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I would take tall the houses off and clean them if it worries you. Shouldn't take too long to remove. just run a bunch of degreaser through them and watch the crap come out. just watch you dont crack any of the hardpipes and rubber "joiners", they like to crack.
    Apr 02 2013
    above top secret
    Yes I appreciate the advise. But my question is how to verify the crankcase condition? Do you get the oil cap dancing like mine as well?
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    It should not be dancing. How is the vacuum going to the intake manifold from the block breather?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 10 2013
    State College PA
    There should be vacuum in the crank case. The blow by from the cylinders should make it have positive pressure, not negative. And what do you mean by dancing? There's is a gasket for the oil cap that makes it snug to the valve cover.
    Apr 02 2013
    above top secret
    Sorry I forgot to state that it "dances" when I loosen up the oil cap during idle. Same as per this video: https://www.youtube.com/watch?v=dsBbaMJoJ-U
    The crankcase is connected to the manifold via PCV valve and SJP. Checked SJP.. no clogs. Checked lines.. no clogs too. Changed PCV and UFO valve to new one. Still dancing though.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Forgive me if I'm wrong, but I'm going to assume you have an AEB engine, therefore no vent in the valve cover. So how could there be vacuum? My cap flutters a little bit, but nowhere as much as the video. But I don't know if that means anything is wrong.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 10 2013
    State College PA
    It's dancing because there is positive pressure in the crankcase and valve cover area. I imagine that's normal. I thought it was doing that when it was tight.
    Apr 02 2013
    above top secret
    I have an APU engine which is equivalent to the US ATW. Yes no vent on the valve cover but there is on the crankcase.
    I guess if everybody else is experiencing this dancing/flutter then I have nothing to worry about.
