Results 1 to 10 of 10
    Aug 24 2010
    burlington ohio
    power steering with 4.2 swap
    so i swapped a 4.2 into 01 a4. ever since doing so my power steering has whined like its low on fluid. i changed pretty much everything pump,rack,pressure line,fluid reservoir,none pressure lines,steering fluid several times. (stock and CH11s fluid)
    any suggestions on what might be going on? have it apart right now and want to try to resolve it for the last time.
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    My boys 4.2 dose the same thing I too would like to know this issue
    Aug 24 2010
    burlington ohio
    yes its wearing me out. haha not sure were to go from here
    Nov 03 2011
    All Over!
    What high pressure line did you use?
    1986 Type 85 Audi 90 quattro
    Aug 24 2010
    burlington ohio
    i did reuse the original A4 pressure line both times i changed it.
    Nov 03 2011
    All Over!
    The A4 1.8T high pressure line should have a built-in restrictor. If it doesn't, the fluid will froth excessively, resulting in air bubbles. This will cause the vane pump to pump mostly air, resulting in a constant whining.
    Aug 24 2010
    burlington ohio
    i will have to check it tomorrow. that sounds exactly like whats happening. will the 4.2 line be whats required? i have a parts car i cant get one from.
    will a banjo bolt with a restrictor work at the pump be a option?
    Nov 03 2011
    All Over!
    Quote Originally Posted by lazerreda4 View Post
    The in-line restrictor looks like a crimped section of the high-pressure line. Make sure whichever line you use has one.
    The damped banjo bolt is usually at the rack end of the high-pressure line.
    Aug 24 2010
    burlington ohio
    i do believe you have solved my issue. hopefully! hahah @nolly thanks so much man! love you builds you have going on..
    Aug 24 2010
    burlington ohio
    well checked the pressure line and it seems to have the restictor in it. so not sure were to go from here. any more suggestions?
