Results 1 to 7 of 7
    Junior Member Two Rings
    Jul 28 2014
    quebec
    Angry 1.8t head gasket question
    i have a 1.8t with 81.5 mm overside piston it is ok to use 83 mm bore head gasket?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Probably, but what's the point? Just use a standard gasket
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jul 28 2014
    quebec
    i can i use the oem one because oversize gasket are all 83 mm bore
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Just use the oem 81mm bore gasket.
    2000 S4- Working?
    Jul 28 2014
    quebec
    the oem 81mm oem head gasket will fit on 81.5 mm oversize ? the hole for the cylinder are not going to be to small?
    Aug 26 2005
    Quote Originally Posted by nicolas543 View Post
    No, the standard 81mm gasket is made larger than 81mm bore, so that will fit the 81.5mm bore size too.
    Vorsprung durch Technik
    Jul 28 2014
    quebec
    ok thank you guys i will put oem head gasket
