2007 Audi A6 3.2 Quattro
2007 Audi A6 3.2 Quattro, Quartz Gray Metallic clean title two owners, 99,XXX miles. Car has been extremely well maintained; Audi Dealership or myself have done all work. Oil changes every 5k. Ran BGG44K cleaner every 6 months. Leather conditioned every 6 months. Car has been taken care of better than I take care of myself. I don't have any kids so most of the time there was only the driver in the car. Interior is pretty much flawless with an exception of a few scratched on the plastic where the belt hits it when you unbuckle the seat belt. There is a small tear in the driver side seat, pretty much non visible. Exterior the car has no damage just few wear and tear minor scratches and chips from every day driving and no rust. Mechanically the car drives great; the car pulls with authority and shifts smooth. I have not had any problems with the car. Only wear and tear stuff that has been replaced. I have put roughly 8 grand in to the car with in the last three years or so in maintenance and modification. I kept all OEM parts, so if you want the car stock I can make it happen! Feel free to email me with any questions. Car has extensive modifications and maintenance done to it: On top of the regular maintenances it has. . .
2016 installments:
Interior trim wrapped in real carbon fiber wrap
New spark plus and ignition coils
HVAC valves cleaned
Carbon Fiber Key
2015 installments:
ST Coilovers
RS5 Replica 19'
New TMPS
New Continental Extreme Contact DWS
Custom front splitter
Custom rear diffuser
Brakes painted with G2 paint
Quattro and Audi Decals
RS Quattro Badge on the lower grille
Blacked out Chrome in front
Custom Exhaust (xpipe and no resonators) designed for no drone
4 Inch outlets angle cut double wall stainless steel tips
HR Sport rear sway bar
Cleaned throttle body and computer update
AC recharge late summer
New headlight bulbs late fall : PHILIPS 5000K X-tremeVision +50% D2S BULBS
2014 installments:
RS Honeycomb side grills with built in DRL LED
Fog Light bulb changed to extreme bright white to match headlights
DRL bulbs changed to chrome extreme white
Turn Signal bulbs Sylvania ST Silverstar
Full LED Kit for the Interior
Tinted windows
Features:
2-Stage Unlocking Doors, 4wd Type - Full Time, Abs - 4-Wheel, Air Filtration, Airbag Deactivation - Occupant Sensing Passenger, Antenna Type - Diversity, Anti-Theft System - Alarm With Remote, Anti-Theft System - Engine Immobilizer, Armrests - Rear Center Folding With Storage, Braking Assist, Cargo Area Light, Cargo Tie Downs, Cd Changer - 6, Center Console - Front Console With Storage, Center Console Trim - Wood, Center Differential - Mechanical, Child Safety Door Locks, Child Seat Anchors, Clock, Cruise Control, Cupholders - Front, Cupholders - Rear, Dash Trim - Wood, Door Trim - Wood, Driver Seat - Height Adjustable, Driver Seat Power Adjustments - 8, Driver Seat Power Adjustments - Lumbar, Electronic Brakeforce Distribution, Emergency Interior Trunk Release, Exterior Entry Lights, External Temperature Display, First Aid Kit, Floor Mat Material - Carpet, Floor Mats - Front, Floor Mats - Rear, Front Air Conditioning - Automatic Climate Control, Front Air Conditioning Zones - Dual, Front Airbags - Dual, Front Brake Diameter - 12.6, Front Brake Type - Ventilated Disc, Front Brake Width - 1.2, Front Fog Lights, Front Headrests - 2, Front Headrests - Adjustable, Front Seat Type - Bucket, Front Shock Type - Gas, Front Spring Type - Coil, Front Suspension Classification - Independent, Front Suspension Type - Multi-Link, Front Wipers - Intermittent, Front Wipers - Rain Sensing, Gauge - Tachometer, Head Airbags - Front And Rear, Headlights - Auto Delay Off, Headlights - Dusk Sensing, Heated Windshield Washer Jets, In-Dash Cd - Mp3 Playback, Limited Slip Differential - Center, Midyear Release - No, Multi-Function Remote, Multi-Function Remote - Trunk Release, One-Touch Windows - 4, Overhead Console - Front, Passenger Seat - Height Adjustable, Passenger Seat Power Ad
List Date: 2/24/2016
For more info, click here to view the original listing: 2007 Audi A6 3.2 Quattro
This item is no longer available.
