Results 1 to 19 of 19
    Established Member Two Rings 2000blk1.8t's Avatar
    Jan 26 2014
    Livingston
    AWM engine replace AMB
    hello all. I recently picked up a 2003 a4 with a 5 speed manual. I have a 2003 passat parts car with a AWM I am going to swap into the a4. I have done some research and I know I have to modify it to fit the coolant flange, so I am prepared for that. I need to get a timing belt kit for it. I currently have some parts laying around. I have a tensioner for an AWM, the hydraulic roller for an AWM, and a contitech timing belt with the part number 058 109 119 c 317. Will this timing belt work? or do I need to order different timing belt?
    Feb 17 2004
    Liberty Hill, TX
    you don't have to modify anything, just use the AMB coolant flange (and all other external accessories). The part # you listed for the timing belt shows as fitting 00-01 ATW/AWM only; I'd just buy the updated TB kit from Blauparts with the new spring-loaded (vs hydraulic) tensioner/roller setup.
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    May 24 2008
    cornish,me
    I recently put an AWM head on to my AMB block much easier than transplanting the whole engine if your rotating assembly and block are good. I used the AMB timing components and coolant flange.
    Jan 26 2014
    Livingston
    The timing was set wrong and a broken valve reaked some halvok on the piston. Kinda smashed the edge of the piston down so its rubbing on the cylinder wall. Just easier to swap engines.
    Jan 26 2014
    Livingston
    so another question for you guys. I am in the middle of the swap right now and discovered this. Looks like one of the previous owners ended up in the ditch or something. Tore the one line up bad, and the other one is just dented up a little. Are these vent lines for the fuel tank? how important are they?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It appears to be the evap purge line. The car will run without it but you will get a CEL and the engine will run very rough whenever the N80 is activated.
    Jan 26 2014
    Livingston
    hm.... anyone know off hand if my 2002 passat parts car would have a line like this I could rob?
    Oct 23 2010
    2004 Atlas Gray A4 Avant
    Cranberry TWP, PA
    The opening for the thermostat housing may have to be massaged a little bit with a dremel and a sanding drum so the electric thermostat housing will seat all the way. Aside from that, the blocks are pretty much identical. All the external cooling parts from the AMB should be swapped over...
    2004 Atlas Gray B6 Avant, built 2.7T w/ BB K24's on E85
    2005 Touareg 4.2 gas guzzling daily
    2002 Triumph Daytona 955i
    1997 BMW M3 Coupe (sold, sad reacts only)
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    What Steve said. I put an AWM motor in a b6 I bought to flip.
    Nov 17 2008
    AMB
    AWM
    Modified AWM
    Jan 26 2014
    Livingston
    thanks! thats kinda what I determend I had to do, but those are the best comparison pictures Ive seen.
    Jan 26 2014
    Livingston
    hey guys. putting the timing belt kit together right now and I just noticed I have the older style tensioner roller. Like from an AEB or ATW. Can I still use it in this car?
    Jan 26 2014
    Livingston
    nevermind. the bolt/stud size is different and it fits sloppy.
    Dec 05 2007
    Block cast is exactly the same. That is what matters, along with internals. But they are 100% compatible and may also be 100% the same. With the AWM outside of the block bare, just install it as you would an AMB replacement and use your AMB parts (all of them). Don't start swapping parts, even though some are or look the same. That is where your confusion will lie. Just swap block for block (absolutely no accessories or hardware) and you will be fine. Easiest way to go about it to avoid any confusion.
    Jan 26 2014
    Livingston
    about the only 2 things I am using from the VW on the engine is the exhaust manifold, and the starter. I am also using the VW passat transmission as it has less miles on it. I did have to do the above shown mod for the coolant flange to fit right. doing the assimbly today hope to have the engine in later tonight. Right now I am off hunting down a tensioner roller and hydraulic tensioner.
    Jan 26 2014
    Livingston
    so I have a bit of an issue now. I have the engine and trans all in ready to go, and the cv axle bolt pattern is different. What the heck? why would everything on the transmissions be the same and this is different? FYI, this car is a FWD not a quattro.
    Dec 05 2007
    Swap the flanges.
    Jan 26 2014
    Livingston
    and how do I do that?
    Jan 26 2014
    Livingston
    never mind. Found it in my vw bently service manual. calls for a puller tool, but I just used long bolts and pressed off the transmission housing. Thanks for the help! That took a load off of my back. Was not looking forward to having to pull it back out. They are both 012 transmissions.
