Results 1 to 4 of 4
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    RS6 - crank, no start
    Drove fine. Parked for dinner. Back: crank, no start.
    Being towed here this morning.
    Any tips/suggestions to for the first troubleshooting steps?
    I plan to first hook up VAGcom, see what codes are stored.
    Then clear codes.
    IIRC, crank sensor ("engine speed sensor") can cause 'crank, no start'?
    Quick test maybe:
    In engine module, measuring block will bring up engine rpm. while cranking, observe if numbers (100 or so rpm?) are showing. Would that rule out the crank sensor?
    Next, would check for spark.
    Next, would check for fuel.
    Other suggestions for 'crank no start'?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Jul 17 2011
    Sin City, USA
    If the is a C5 RS6, then you are posting in the wrong section. Should post over in the C5 section.
    '09 C6.5 A6
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    Where is your C6 RS6?
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    We must have the most number of erroneous cross posts of any other model line. C7s and C5s all day!
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
