    Feb 18 2016
    levis/Quebec/canada
    Gas smell inside the car
    Hi
    Does anyone herver had this probleme: I have a strong smell of gas inside the cabine. We can smell this alsow from outside the car. I've changes my N80. Can it come forme the flexible or the pcv valve?
    Nov 15 2011
    Montreal | I sell in USD
    Have you checked the connection at the bottom of the hpfp?
    Also, lift the bottom of your rear seat by the front portion it will unclip, then smell around there. (The access to the gas pump, fuel level sender are there and you might have a bad seal)
    Welcome aboard Roxanne :)
    *****I sell in USD*****
    Dec 23 2011
    Like Axis said, remove the rear passenger seat and then remove the cover over the gas tank. There is a seal between the gas tank and rear seat which if bad would cause it to smell like gas in the car.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Did you just fill up or did it just randomly happen?
    Veteran Member Three Rings leftovers's Avatar
    Apr 14 2009
    ottawa, il
    Check the connection at the HPFP. I had mine loosen on me after working on my cam follower. I could definitely smell it inside.
    2004 A4 Ultrasport, 1.8T, 6MT
    Instagram: audi_ute_build
