Results 1 to 7 of 7
    Sep 03 2015
    Hobart Australia
    Audi Special Tool 3369
    I am interested in fabricating a tool that replicates Audi Special Tool 3369.
    Having not used the tool I do not understand why the sleeve encasing the bolt has a slit along it's length. Could someone familiar with this tool explain why the tool is made this way.
    Thanks
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Refresh my memory, is this for the lock carrier?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Four Rings OGBULLYLOCDAWG's Avatar
    May 28 2011
    C5 A6
    NY/PA
    I can't explain the reasoning behind that, but you can use the bolts that you take out from the fog light grille area (they go up through the bumper shocks).
    They work just fine.
    Feb 05 2008
    Waterloo NY
    What he said ^^^ certainly no sense in spending the money on those when a 4 inch bolt works just fine.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Senior Member Three Rings bpark1210's Avatar
    Jan 08 2016
    PNW N. of Seattle
    Better yet don't even fuss w/ the lock carrier bolts. I didn't when I did my TB job. I just let the lock carrier hang, it frees up more room. Just make sure you get your AC/Coolant lines in good position from pinching and you'll be fine. On my Passat when I performed the 1st TB I went to the hardware store and found bolts w/ the correct thread/pitch as an alternative. No need to dish out big bucks for a simple operation.
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Here's some instructions if you want to be fancy and make a set for yourself:
    http://plexcomols.com/clients/b5one/howto/radtool.pdf
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    I just used some cheap lag bolts I had laying around the garage. Worked fine.
