Results 1 to 18 of 18
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Has anyone seen this? Remote control phone with head unit?
    I was just browsing seeing what my options are to improve my phone to head unit. auxiliary and what not and saw this
    https://m.youtube.com/watch?v=MH58wGjOxm4
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by Osher67 View Post
    It's simply mirroring. If you get an android head unit, it can be done.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Nov 03 2012
    California/so cal
    Quote Originally Posted by manhertm View Post
    It's not just mirroring, it's controlling the phone too there's not many things that do this with full functionality. I can mirror my phone to my tv, but not control it with my tv (I mean yeah Apple TV play pause fast forward rewind that's it) same for any head unit with an hdmi input or video input.
    I can't find anything on it really seams it was posted 2 years ago
    Only other one I found
    https://m.youtube.com/watch?v=uEPu-q70cTQ
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    I have a pioneer app radio3 sph-da210 that I use to mirror and control my android phone with mhl connector, the MHL of course does the video out and the screen control is done via Bluetooth. I don't know if it can do the same with an iPhone without jailbreaking though.
    Aug 27 2013
    Philly
    Quote Originally Posted by chad99 View Post
    I was just wondering this morning if anyone else was using an AppRadio on this forum. I use an AppRadio2 + Chromecast to mirror my Nexus 6 to my radio. I love it. I couldn't live without it any more. I used to use an MHL adaptor, but the charging rates were too slow when streaming music+using GPS apps. Sound quality dropped getting rid of the MHL adaptor, but most manufactures are dropping MHL support from their USB port anyway. I need to look over my grounds and power wires though, as I am getting some interference through the speakers that moves with the speed of the engine. I even have a capacity box built to fix this, but its not helping.
    This is a good time to ditch your iPhone for an Android. Not to mention everyone knows theres more functionality with Androids, but I'll leave that smack talk for another forum
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Yes it is. It's called mirrorlink and it doesn't work on your TV, because you TV doesn't have a capacitive touchscreen or CPU that can do it ,but these android headunits do.
    Aug 27 2013
    Philly
    And you need an app to "hand off" the touch inputs. Chromecast and Mirrolink cannot do this on their own. I use AppRadio Reloaded ($30) and its worth every penny. This app controls the negotiation between mirroring device(chromecast or miracast), the radio and the phone. It totally not a simple plug and play setup.
    Apr 25 2014
    Downey, CA
    What mhl adapter are you guys using?
    Sent from my SM-N910T using Tapatalk
    Using Tapatalk
    Aug 27 2013
    Philly
    Quote Originally Posted by AutoMax View Post
    For the Pioneer AppRadio is recommended to use the Pioneer brand one. I can totally sell you the mhl portion as i don't use it anymore. You'd just need the power box it plugs into. I may have the iOS cables laying somewhere. Not sure though
    Sent from my Nexus 6 using Tapatalk
    Apr 01 2015
    2004 Audi A4 B6 3.0 Quattro, 2015 GMC Terrain, Infiniti G35 Coupe
    United States
    I have an AppRadio3, rooted my phone (to enable hot spot and control phone via Bluetooth), purchased AppRadio Unchained. I can control my whole phone via the head unit through a Chromecast. Easiest install I did with parts from enfig.
    Apr 25 2014
    Downey, CA
    Quote Originally Posted by coffeysm View Post
    So, your chromecast plugs in through usb or hdmi to head unit and phone plugs in to chromecast? ? Care to share more details?
    Quote Originally Posted by SJorge3442 View Post
    Link to power box? I def am interested in setting this up in my car
    Using Tapatalk
    Apr 01 2015
    United States
    I have the AppRadio 3 installed with a USB and HDMI cable running into my glovebox which connect to the Chromecast.
    You then need an active WiFi spot for the ChromeCast to mirror your display to the head unit. Sprint wants an extra 30 dollars a month for this, I refuse to pay that, so I Rooted my phone and enabled it. (My phone now acts as the hotspot)
    AppRadio Unchained connects via BlueTooth and also requires Root, so you can control the phone from the head unit via the touchscreen.
    You can also install Tasker to perform automatic functions like connect to WiFi, start AppRadio, turn the bluetooth on/off.
    My whole setup is wireless minus the HDMI and USB cable from the head unit. I also used Enfig adapters, so the whole head unit install was pretty much plug and play.
    I installed remote starter in my wife's Subaru and Kenwood setup in my G35. The setup I have in my Audi was the easiest I've ever done and took about an hour or two.
    I might install remote starter in my Audi and G35; I defintely want to put the same AppRadio setup in my G35, but budget constraints you know?
    Apr 25 2014
    Downey, CA
    I think i understand your setup, just a question to clear things up... my head unit needs a hdmi input right?
    Using Tapatalk
    Apr 01 2015
    United States
    If you're going to the route I went then yes. I think the AppRadio2+ all have HDMI inputs you also need to provide power to the Chromecast. You can do that with a USB input.
    Aug 27 2013
    Philly
    Yeah AppRadio2 and up. Basically the only differences moving up in models is screen resolution.....I want a new one
    Nov 03 2012
    California/so cal
    Good thing I am jailbroke since iOS 3 lol
    I can't have iPhone without jailbreak
    But this is news to me didn't know you can mirrorlink like that
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2012
    California/so cal
    This is really cool I need to learn more about rooting side of android
    I notice you say you stream most of the time maybe interference from that?
    But otherwise what is mhl exactly?
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2012
    California/so cal
    Just found this appradio extenchions tweak but not updated especially not for iOS 9 :/
    https://m.youtube.com/watch?v=6oVYiKnAE6g
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
