Results 1 to 12 of 12
    Sep 21 2014
    San Diego
    Unhappy car miss firing????
    when i shift into forth gear and try to punch it my car doesn't go, it just goes then slows and goes again(like a jack rabbit) any answers i was thinking of replacing the wiring to the coils cut the heat from the exhaust has kinda baked them
    Established Member Two Rings Detroiter's Avatar
    Apr 05 2015
    Michigan
    When was the last time you changed your spark plugs? When I first changed my tune to stage 1+ the added boost kept causing the spark plugs to break up resulting in rapid misfiring. Once I replaced them with some new ones it solved the problem.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    What codes are stored on the ECU?
    Sep 21 2014
    San Diego
    I've replaced the plugs and the coils and my code reader isn't picking anything up yet
    also i replaced the this jet suction pump like a month ago ? maybe its bad?
    I've heard that replacing the coil wires might help because the plastic connection to the coils are falling apart
    Sep 21 2014
    San Diego
    i also replaced this air pump check valve and to be honest idk if i put the darn thing in the right way but I'm like 70% that i did tho ... :/
    Oct 02 2006
    Wadsworth,OH
    Have you checked for boost/vacuum leaks? A leak can definitely cause misfiring. Do you have a boost gauge installed? If so have you noticed a drop off in boost pressure?
    Jason
    Sep 21 2014
    San Diego
    i don't have have a boost gauge how els could i check it?
    Aug 12 2009
    Dirty Jerz
    If you don't have any stored codes on the ECU, then the car is likely not misfiring. Does the CEL blink when this happens? Also auto or manual?
    Sent from my DROID Turbo 2
    Sep 21 2014
    San Diego
    Quote Originally Posted by imnuts View Post
    Ok so the code that popped up is P0442 evaporative emission system leak (small) but I don't know if that has anything to do with the missfire
    Aug 12 2009
    Dirty Jerz
    If there was a misfire, you should have a code for the misfire. So far, I haven't seen anything to suggest you have a misfire either. Does the car shake when this happens? Is it only in one gear, or all of them?
    Sep 21 2014
    San Diego
    its mainly in 4th gear but it happens in 3rd sometimes
    Aug 12 2009
    Dirty Jerz
    Are you sure it isn't a transmission issue?
