I have a set of euro (Ecode) D3S, Bixenon, AFS, headlights coming.
Before I install them, I'd like to try a conversion to D2S.
Aside from a slight modification (notching) of the D2S bulb base, can I assume it will fit into the existing D3S igniter?
If so, can I also use an after market 50/55W ballast with that igniter? Or would I need to replace the igniter to a D2S one?
If it's a case of replacing all 3 - D2S bulb, D2S igniter and D2S (55W) ballast, will that ballast still plug into my existing headlight harness?
My bottom line is I like achieve greater lumen output through the use of a higher wattage ballast but I'm not 100% sure of the inter - connectivity between the requisite components and existing headlight harness.
