Results 1 to 8 of 8
Thread: Car chokes
    Established Member Two Rings GottaBAUDI's Avatar
    Sep 01 2015
    Syracuse NY
    Car chokes
    Barely passes 5psi and will choke and stop accelerating. Can it be a vacuum leak?
    Sep 01 2015
    Syracuse NY
    Sent from my SM-T817V using Tapatalk
    Sep 01 2015
    Syracuse NY
    May 16 2008
    WA
    you could be in limp mode, or hard throttle cut, but you need to scan the car, preferably with vagcom and see what it says its angry about. Even if there is no CEL, there can still be codes.
    Once we have that info it will help point to whats going on.
    Also, post up information about your car. Is it stock ECU? tuned? What PSI should it be seeing? Is this a new problem, or something its done since you have had it?
    Active Member Two Rings B5Mark's Avatar
    Jan 15 2016
    Colorado
    Yeah like he said^
    I had the same problem ended up being my EGT sensors. I just got EGT deletes. Vagcom should tell you.
    00 Audi S4 / Stage 1
    Check out this sick B5S4 Fanpage http://www.instagram.com/b5s4
    Sep 01 2015
    Syracuse NY
    It's stock 10psi
    Sep 01 2015
    Syracuse NY
    Also if I unplug my maf then it will boost up but then sometimes when I get past 4k rpms it'll start to hesitate like a misfire. Eventually it does misfire
    Jan 15 2016
    Colorado
    Yeah so get a vagcom. Mine literally did the same exact thing.
