2001 Widebody S4 Avant
Here it is everybody. I no longer have the time or garage space to part this car out. Everything is solid on the vehicle and like new. Only problem with the car is a leaking rear main seal, the tint on one window is lifting up, and the passenger side front grille has gone missing. The car still starts and runs but I would take it away on a trailer as the leak has become pretty heavy. I would love to keep this car, fix the seal and drive it but I recently picked up a 1957 Thunderbird and a 1959 Corvette I have plans on finishing up. If you have the mechanical know how, this is an easy and cheap fix for someone who has wanted a widebody avant. You could not possibly build this car for the price I'm asking. $20k takes her. Clean NJ title along with extra keys. Pictures in the link below
http://s1198.photobucket.com/user/calvinyoung/library/?view=recent&page=1
2001 Widebody Audi S4 Avant
Mileage 87xxx
Engine Mileage 17xx
6MT
Clean New Jersey Title
Widebody Conversion Done by Global Motorsports Group in Santa Ana, CA 92704
Exterior 8.5/10
Interior 9/10
Bottom End
-New OE 2.7 Pistons
-New OE Piston Rings
-Rpm Connecting Rods
-OE Wrist Pins
-Fresh 2.7 Crank
-OE Rod & Main Bearings
-OE Main Bearing Cap Bolts
Cylinder Heads
-Stock 2.7t
-2.8 Intake Cams
-New OE Lifters
-New OE Intake/Exhaust Valves
-New VSS/Guides
-OE Cam Chain Tensioners
All Ends & Odds
-SRM K24 Rs6 Turbos w/ Inlets & Braided Oil Feed Lines
-New OE Oil Return Lines
-Paragon Performance Braided Wastegate Lines
-ARD/Vast Bi-Pipes w/ Meth Bungs
-Ceramic Coated Rs4 Y-Pipe
-SRM 85mm Intake w/ Hitachi Maf
-710N Diverter Valves
-034 2.0 Coil Conversion w/ ICM Deletes
-BKR7E Spark Plugs
-VAG Autowerks Coilpack Adapter Plates
-034 Bosch 044 Fuel Pump
-EV14 60lb Fuel Injectors w/ Adapter Clips
-Aquamist HFS-3 Methanol Injection Kit (Gauge In Vent)
-NewSouth Performance Analog Boost Gauge (In Vent)
-PLX DM-6 AFR Gauge (In Vent)
-OE Ceramic Coated Exhaust Manifolds
-SSAC 3" Downpipes (Wraped in DEI)
-SSAC 3" Test Pipes
-SSAC Twin II Rep (Cut out middle resonator and left rear resonator)
-JHM Short Shifter Kit
-Project B5 Stage-X Clutch Kit
-Resurfaced OE Dual Mass Flywheel
-Apikol Lobster Claws
-034 TBB
-034 Diverter Valve Hoses
-034 Power Steering Supply Hose
-034 Silicon Spider Hose
-034 After Run Pump Delete Hose
-034 Snub Mount
-Stern Motor Mounts
-Stern Transmission Mounts
-Apikol Rear Diff Mount
-Stern Adjustable Upper Control Arm Kit
-Bilstein Pss9 Coilover Suspension
-New Rotors & Pads On All Four Corners
-Electric Fan Kit w/ Cover Plate For Clutch Fan
-New Coolant Expansion Tank
-Porsche 911 Coolant Cap
-Porsche 911 Oil Cap
-New Front Timing Belt Cover
-Refinished Rear Timing Belt Covers
-New Metal Thermostat Housing
-New Alternator
-New Starter
-New Serp Belt Tensioner
-New Serpetine Belt
-New Timing Belt
-New Idler Roller
-New Tensioner Roller
-New Hydraulic Tensioner
-New Relay Lever
-New Water Pump
-New Cam Seals x4
-New Cam Plugs x2
-New Valve Cover Gaskets
-New Cam Chain Tensioner Gaskets & Plugs
-New Head Gaskets
-New Valley Pan Gasket
-New Rear Main Seal
-New Crank Flange Gasket
-New Crank Seal
-New Crank Bolt
-New Thermostat w/ O-Ring
-New Coolant Crossover O-Rings
-Every Coolant Hose Replaced NEW
-Corbeau TRS Racing Seats Silver Suede (Driver & Passenger Heated)
-White Alcantara Interior
-OE Piano Black Belt Line Trim, Hazard Surround, Shifter Surround, Ash Tray Cover
Short Block, Valve Covers, Coolant Crossover Pipe, Power Steering Hard Line, Upper Oil Pan, Front Crank Flange All Powder Coated For That Fresh-New Look. Cylinder Heads Have Been Refinished In An OE Aluminum Color
List Date: 2/23/2016
For more info, click here to view the original listing: 2001 Widebody S4 Avant
On Sale For: $20,000.00
