Originally Posted by
phillyquattro
LOL at the paperclip comment!
Why do you think there wouldn't be any performance gained though? Assuming a rear kit would have a slightly larger rotor (maybe 320-325mm) and likely a better caliper you should see improvements in heat dissipation, wear, fade, and perhaps ever so slightly in stopping/slowing distance. Totally agree though that it might not be worth the cost (assuming here the cost would be pretty close to the front BBK due to the electronic parking brake integration).
Quick random question for you while we're on the subject. I plan on replacing the rear lines when I install the StopTech kit and I have the system bled. Do you know if I need to disengage the parking brake for that?
The rear brakes don't suffer from brake fade that I'm aware of and they don't have trouble achieving full lock (or technically, ABS point) so there is no performance to be gained. Remember, upgrading brakes does not result in decreased stoping distance. Only decreased fade and thus stopping distance is remains consistent after multiple stops. There are some other benefits like increased pedal feel, but the rears do only 20-25% of the braking so it really wouldn't be noticeable. Decreased pad wear from a larger rotor would probably happen, but that's mostly a convenience gain rather than a performance gain.
Good question about the parking brake. I've never though about that before and when I bled my rears I don't remember if I had the brake set or not. In the future, I think I will try to bleed them without the parking brake engaged, but I think either way is fine. Just make sure to monitor fluid level in the reservoir, of course.
