Originally Posted by
adamazing
You have the S-Line Exterior Appearance Package.
There is also an S-Line interior package as well, but odds are you probably don't have that unless you have Alcantara seats and flat bottom steering wheel.
Thank you. I had not seen that in the options list I was referencing on Motortrend. Do not have the interior.
What about the suspension? I had seen 3 levels of suspension referenced on the forums. Is the exterior package divorced from that? Do I probably just have the base "comfort" suspension?
- - - Updated - - -
ToddBrunswick
Also, if you want more info about your car, look in the truck where the spare is. You'll find a sticker with a bunch of codes. Put the codes in this website
http://prsearch.planetvag.com/
Great to know, thanks!
- - - Updated - - -
adamazing
Good point, I forgot to touch on that part.
OP, all 2009-2016 A4 sedans come with side side (dual tip) exhaust regardless of trim.
Ah, that must be an S4 trim piece then? Or is it strictly aftermarket?
