You spoke, we listened! Available with Carbon or Silicon throttle body inlet pipe!
Crafted to fit your 3.0T using all stock mounting locations, the all new Audi B8/B8.5 S4 Luft-Technik Intake sets a new benchmark in appearance, affordability, and durability - all while resisting the performance-robbing effects of engine heat soak.
ECS has subjected this system to rigorous real-world testing, including power/efficiency measurements on our in-house chassis dynamometer.
The convergence of perfected fitment, industry-standard quality, low-cost, and evidence-based performance claims has resulted in a gorgeous power-enhancer beyond anything available for your 3.0T!
The ECS Tuning Luft-Technik Intake System features:
- Hand laid Carbon Fiber or Wire Reinforced 5-ply Silicone intake tube , carefully contoured to allow the smoothest flow path
- Powder Coated twin-layer aluminum heat shield
- 3" conical hi-flow reusable air filter; featuring 8 ply cotton gauze construction and a bell mouth inlet to minimize restriction while maximizing filtration efficiency
- 4-ply silicone couplers with stainless steel hardware & hose clamps for exceptional corrosion resistance and durability [Carbon Only]
- Broader and smoother torque curve for an enhanced driving experience
Gains of +16 WHP / +10 FT-LBS WTQ on APR Stage 2+ ECU Upgrade with the APR supercharger pulley
Breath Easy
Fits:
Audi B8/B8.5 S4 3.0T (2010+)
Be sure to check out our -----> Installation PDF <-----
Jason
