2001.5 Stage 3 AWE
Full AWE original welded exhaust from dowpipes to twin 2. Testpipes as well. (manifolds not included)
New VMR 718s with new general maxas03
Mileage: 186000
3k work done two weeks ago by voodoo autoworks
New timing belt (all options)!
New fuel pump!
New oil pump and pick up and all gaskets!
New engine mounts!
New Spark Plugs!
New OEM All weather mats!
Tranny and Diff fluid swap (Motul)
All programs including boost and race file for 104 octane.
Awe intercoolers
Awe boost gauge in vent
Rs4 clutch kit (holds up perfect)
Samco red hose upgrade kit
Awe pedals
Awe DV1 diverter valves
Awe Dts bar
I don't have the flashloader anymore but you can change programs with the free software awe giac provides.
Poly rear diff mount.
Awe Fueling kit with injectors (full stage 3 good for 460/455 on 93 octane but it's probably around 480)
http://www.awe-tuning.com/awe-tuning...ance-turbo-kit
List done within the last 5k miles:
Bosch Alternator
Aluminum OEM RS6 Thermostat housing
Water Pump
Complete Coolant System Flush
Intercooler Flush
New OEM G12 Coolant
Serpentine Belt
AFE ProDryS drop in filter
Harness rebuild and insulation
New secondary O2s spacers in test pipes
034 Ceramic coated Bi pipes stealth tapped for Meth option if added.
Samco bypass couplers
All Transmission and Diff fluids replaced with Motul
Hood shock
JHM Billet SSK
Full interior and trunk LED and license plate LEDs
IAT, TOS, Throttle body clean
Refreshed aged vac line
Fuel Filter (super pita)
Heater core! OEM blows hot as hell!
Cabin filter
AC evacuation and Recharge
Wiper blades (may be due in a while though)
OEM Tierod
Strut Mounts
ST coilovers used but maybe 30k on them
Hotchkis Sway Bars front and rear. Ridiculous on rails this car is.
Front and rear redstuff brake pads. Front rotors with brake flush. Rear rotors will need to be replaced soon.
Custom performance alignment
Diesel Geek Panzer skid plate is off but will be sold with car
New OEM lower grill
New battery tray plate cover
RS4 leather air shift knob
Depo Ecode headlights
Morimoto 55w HID ballasts
55w Phillips bulbs
Nokya Ultra white 75W highbeam.
I'm sure I'm missing a few things but that's the bulk of it.
I can send pics as needed. I will be more than happy to answer any questions as well.
Now for the negative:
Headliner is sagging and needs replaced.
Rear rotors need to be replaced
valve cover gaskets due soon.
Tires are needing replaced soon as these are summer comps and drivers front showin signs of wear on inside camber.
Don't be afraid to make an offer. Worst I can do is say no
List Date: 2/23/2016
For more info, click here to view the original listing: 2001.5 Stage 3 AWE
This item is no longer available.
