I am going to try and keep this as up to date as possible and ask all of my questions here. I haven't really been active in a good while but as circumstances have changed I will be holding on to the A4 for another year or two anyway.
I have a few things on my list that I need to get sorted and they will be addressed in order of priority. My plan is to get the car to a nice comfortable ~300bhp specification as I am passed the days of solid mounts, loud exhausts and unbearable NVH.
- Clutch
- Chain Tensioner
- Turbo
- Turbo Inlet Pipe
- Black Headliner
- Replacement lower front bumper (I butchered mine when I fit the FMIC a few years ago)
- Replacement headlights
A quick run down on the current state of my car as I have removed alot of the performance parts (built engine, exhaust etc.)
- Revo 550 file
- 550cc Injectors
- K03 turbo
- 034 Sports CAT
- Spec Stage 3+ with Dual Mass flywheel
- Fluidampr
Everything else is stock; inter-coolers, exhaust, engine and intake
At the moment I have my K03 fitted as I am debating on whether to send off my GT2871 to ATP to be replaced under the exchange program OR fit my hybrid K04 that I have sitting up from years ago.
The K03 although running safely does not do as the Revo file requests even on a low boost setting. If I set the Revo file to give me 10psi boost the K03 will only boost to 5 psi. 15 psi gives 7 etc.
I reckon this is due to the boost spike of the K03 turbo. The Revo file is probably looking for a nice linear boost curve and when it sees the massive spike it pulls back on the boost request.
This leaves me reluctant to fit the K04 as I more than likely wont be able to tune it myself properly with the SPS.
The GT2871 is probably going to be sent off for exchange.
Anyway.....
At the moment I am trying to decide the best clutch option for my goals. I have looked at most if not all options; ECS RA4, JHM RS4, Valeo Single Mass conversion.
My Spec Stage 3+ clutch is starting to slip. I have replaced the disc from a stage 3 to 3+ in the past and noted that there was scoring on the pressure plate so I plan on replacing the whole lot (pressure plate, disc and flywheel).
I also still have my steel single mass flywheel from Spec when I first bought the stage 3 clutch kit. The RS4 clutch kit is available for €350 from a local supplier (Ireland) so I have plenty of options.
So as I see it here are my options:
- Purchase the whole RA4 kit from ECS - single mass could potentially introduce clutch chatter
- Purchase RS4 clutch kit locally and have my Spec single mass machined to suit - is this possible?
- Purchase a new performance pressure plate and disk and new OE Dual mass flywheel.
Is it possible to fit the RS4 clutch kit to a Dual mass flywheel from the 1.8t?
