Results 1 to 4 of 4
Thread: p2015 code
    Sep 06 2012
    Birmingham AL
    p2015 code
    Before I get flamed yes I have done my research and reading. I am posting this because I couldn't find a definitive answer. Does this code always mean the manifold needs to be replaced?! Is there a separate part for the IMRC motor that can be replaced to fix this? I didn't get any other codes along with this one.
    The car really doesn't idle or run poorly or feel like there is a lack in performance. The code popped up under hard acceleration on the interstate. Should I try clearing it and see if it comes up again before worrying that I need to replace parts?
    Also, the air filter hasn't been replaced in a while (I know shame on me but I can't remember the last time it was replaced. maybe 35-40k miles ago). I know this is probably a long shot but is there any way that this could cause this code to pop up due to restricted airflow and not an actual issue with the manifold or actuator motor?
    Car is an 09 with 97K miles.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Stage 1 more than you RS3
    Sep 06 2012
    Birmingham AL
    Thank you this is what I have read already about this issue.
    But this doesnt answer my question. Without any sign of power loss or poor idle is this definitely a problem that warrants replacing the motor or whole manifold, or could it be something intermittent or even possibly caused by inadequate air flow due to a clogged filter?
    I may dig into it more tonight to see if I can see or feel any obvious vacuum leaks that may be caused by this, but as I said the car isn't running poorly like there is a vacuum leak or unmetered air being pulled in.
    Sep 06 2012
    Birmingham AL
    Does our car use the same motor actuator (V157) as the TDI Jettas?
    Found this interesting:
    https://www.youtube.com/watch?v=0HbIL5u0bng
    Gonna check this out tonight and see if it could be something as simple as this.
