Results 1 to 4 of 4
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Xenon issue...suggestions?
    My xenon headlights on my A6 were not matching properly and I figured at one time the previous owner may have replaced a bulb on one side and not the pair like you are supposed to. One was a nice blue (passenger), while the other appeared to be more of a white (driver) and it drove me crazy. So last week I ordered up some 5000k D2S bulbs from HIDconcept and I put them in last night and to my surprise they still do not match. While they both have a little more blue to them now since they are 5000k, the driver side still appears to be less colored than the passenger. I did notice that when I opened the casing on the driver side light that there was light dust inside as compared to the passenger. I am thinking maybe moisture got into the housing and possibly tampered with the igniter? Sometimes the driver side light wont turn on and I am thinking the igniter may be the issue? Does anyone have any suggestions?
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by QuinnsterKID View Post
    IIRC, there is not an "ignitor" in the the xenon setup; just a ballast. I would hazard a guess that your ballast is failing and the light is not getting the required voltage hence the color difference.
    '09 C6.5 A6
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    I experienced same thing. I replaced both headlight bulbs to Morimoto 5500k and one had slightly more white in it. I noticed that one of the back headlight doors had broken clips and was not sitting there tightly. It allowed air and other stuff to get to the headlight. I noticed that this projector lens had bit more dust on it that the other one. This was the reason why I was seeing slight color difference.
    You will experience the same thing when one of your headlight has that yellowish haze on the headlight lens and the other does not. I did that experiment when polishing headlights on my co-workers' audi A4.
    First, make sure your headlights are equally clean. (turn on the headlights and take a close up look at both projector lenses and see if they have equal amount of dust on them)
    Second, swap the bulb sides and see if it is the bulb that gives you a different color or a headlight.
    If there is no difference than you need to look into the ballast or igniter.
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    I know that my 2009 has D3S bulbs, so the igniter is built into the bulb base. For 2008, I assume it's D2S and would mean the igniter is inside the driver housing.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
