Originally Posted by
4rings2turbos
Is there an S6 01E writeup somewhere? I'm half heartedly looking around for an opportunity to scoop parts/full car to swap.
209k on original trans, is this real life!?
There are some write ups and a few little build threads. Seems like the old threads aren't easy to find or they're gone.
but basically:
Add clutch pedal and clutch master and line to slave.
Add wire from pedals to pin 39 Ecu, jump wire from brake switch to clutch switch.
Remove exhaust.
Remove old trans, TCU and shit, flex plate, driveshaft, shifter and that junk.
Add flywheel clutch, etc.
Install shifter, 01e trans and axles, driveshaft.
Gut catalytic converters. Reinstall exhaust
upload your 559E file w/ Nefmoto. Do some coding and drive.
There are a few little things on the side like shifter adjustment and reverse switch wiring. But for the most part it is really pretty straightforward.
