Results 1 to 2 of 2
    Apr 24 2015
    Sc
    2010 tail light question
    i need to replace the left rear outer taillight on my wife's 2010 3.2. Can anyone tell me what the difference is between the different model numbers? Specifically the end letter. The part number on hers now is 8TO 945 095 E. And I have found some with the same numbers that ended with A. Does anyone know if this will fit? Any help is greatly appreciated.
    Established Member Two Rings Crusader105's Avatar
    Jul 22 2014
    2010 Subaru Forester XT, 2005 G35 Coupe, 2006, 2015 WRX STI Kawasaki 500R, 1986 RX-7
    Elora, ON
    I work for a company that directly supplies parts to VW and the letter at the end indicates the design release level of the part. The A is an original version of the part, the E would be a higher level to suit your particular model.
    The design change might be minor from A to E, sorry can't help you with that. Probably best to replace with the correct level part to avoid any surprises.
    Maybe ask your local dealership for help?
    2010 A5 Prestige in Meteor Grey Pearl/S Line/Tech Pkg/M6/CR-15 Front Strut Brace
