Results 1 to 29 of 29
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Those with 10.5" wide wheels
    I'd like to reach out to those running 10.5" wide wheels, I'm not too concerned about rim diameter than I am about tire size. What size tires are you running and if you could post a picture I'd greatly appreciate it. I am still trying to figure out what size I want to run on a new set-up I will be picking up soon. I am leaning towards a 275/30/19 but may make the jump to 285. Thanks in advance!
    "Brake last, finish first."
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    285 is too wide unless you go with a narrow tire like a Hankook V12 which are actually 275 width. On a 19" wheel, a 275/30/19 fits really well. On an 18" like I am running, 275/35/18 is the way to go.
    Fender fitment is can be seen on the white car here:
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by BenSti View Post
    Thanks for the info Ben! Out of curiosity what offset are you at in this picture?
    Mar 11 2008
    B7RS4 & e46Ms
    Yeah, Ben nailed it. The 285 hankook v12s are the same width as the 265 RS3s. 275 is the way to go
    FRRG AZ Ring
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by NYC_Legacy View Post
    18x10.5 +25 square
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    I got 19x10 ET29 OZ Ultraleggera HLT rims with 275/35 ZR19 Michelin Pilot Super Sport installed on mine and they fit like this.
    The Michelin is a very wide tyre due to a thick side wall. I'm on stock ride height and DRC suspension. The tyre size causes no problem with spirited driving, but under track conditions the tyre gives a bit way just enough to rub a bit. On this picture you can see where they rub a bit under very hard cornering.
    Here you can see how far over the rims edge the tyre wall actually reaches.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Oct 14 2009
    AZ/NY
    Wow great info Ven0m, Thank you for all the pictures as well.
    Jun 25 2009
    07 RS4, 91 BMW 318is
    SC
    Quote Originally Posted by ven0m View Post
    Good to know a 275/35 on 19 will fit. I wanted to go this route instead of 275/30 but wasn't confident of fitment on a +25 offset. Rolled fenders and maybe a little extra camber would likely be needed.
    May 10 2015
    Slovenia
    @NYC_Legacy; Much obliged to help. I wasted hours calculating and busting my balls if these would fit before I bought the rims and tyres.
    Quote Originally Posted by komseh View Post
    The only time it rubbed was in some VERY tight corners on the track - when the shocks were completely compressed. It slightly grazed the rear wheel wells and on the front the inside wishbone. All suspension setting = STOCK.
    If you'll put ET25, that's 4mm more out than my ET29. The rear would be fine with a small camber adjustment if you have adjustable arms. But at the front a 10" wide rim would poke-out from under the fender.
    For me at the front 10" rim and ET29 the rim is completely and absolutely straight with the fender, but then the Michelin bulky side wall pokes-out just a smidge.
    Front fittment:
    James May: "Yes."
    Feb 23 2010
    Nebraska
    20x10.5 et25
    265/35/20 Hankook V12's:
    ~ Matt J
    IG: @rsrtsvt
    '08 RS4 -- Suzuka
    991.2 GT3 -- Chalk (SOLD)
    '15 R8 V10 Plus (SOLD)
    '07 PB Audi RS4 (SOLD)
    Oct 14 2009
    AZ/NY
    Matt, every time I see you car I wish I would have bought it, but Sprint Blue just got to me. Pics help a great deal, I'm 99% sure I am going to go 19x10.5 with an offset of ET 23 or 22mm on a 19x10.5 as seen in this members car below (265/30 tire). Although I know we are talking fractions of an inch and camber also plays a big roll in things. Perhaps why your ET25s look to "poke" a bit more.
    Senior Member Three Rings bigoltater's Avatar
    Jan 27 2015
    2013 Q7 S Line / Prestige, 2005.5 S4
    Bend,OR
    Quote Originally Posted by ad2330 View Post
    20x10.5 et25
    SWEET MOTHER OF JESUS!!!!!
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jun 25 2009
    SC
    I have 19x9.5 though, so it should fit quite nicely.
    Senior Member Two Rings 2008s4's Avatar
    Oct 28 2016
    Central, CT
    20x10.5 et25
    I know this is an old thread, but I am looking at the same wheels. 19" just doesn't seem to cut it on the RS. These are 265/30 in the pictures would 275/30/20 fit without fender modifications? I'm on H&R coilovers. Also want a wheel that I don't have to run spacers on...love my Forgestars as they are super lightweight for their size but they seem just slightly too small.
    2008 S4 Brilliant Red (sold) | 2008 RS4 Daytona Grey (sold)
    2008 A4 2.0 Avant (sold) | 2016 S4 Misano Red MT, APR stg 1, RS5BBK (sold)
    2014 MB E63s Wagon Eurocharged stg 1 monster | 2015 Q5 3.0
    Veteran Member Three Rings bluebull's Avatar
    Aug 29 2014
    2017 R8 Nardo boosted with VF; 2017 SQ5; F250
    Portland, OR
    Beef’n 19x10 rotiform et29 275/30-19, Michelin ps4s, Ohlins set on street mode, 1100lb rear eibach springs, 25.5” ground to fender height... extreme minimal rub only at highway speeds hitting sharp dips
    TVS1320 APR, TTX36 Ohlins coils, DXD Flywheel + Clutch, JHM Shift Goodies, Euro Sport Reacecloth Seats, 034 mounts, Stern UCA, JHM full (resonated) exhaust with v-band test pipes and HF cats, JHM short shifter, Rotiform 19x10 with 275 PS4S, Fender to ground is 25.5", ceramic coated and PPF.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by bluebull View Post
    I didn't know you were in Oregon. What area? I've got family scattered all over the PNW. Brother works at Nike and lives in Garden Home.
    That rear end shot of your car looks sick.
    Aug 29 2014
    Portland, OR
    I can see the sky cranes sitting on the Nike world campus from my house... so, Beaverton OR.... Garden Home is also minutes away depending on time of day.
    Let me know when you’re in town...
    Nov 12 2015
    Oregon
    I'm just south of you guys. Nice looking car!
    Sent from my SAMSUNG-SM-N900A using Audizine mobile app
    My build log
    Oct 28 2016
    Central, CT
    After looking and searching, I've come to decide that 10.5" is too wide (for me and my taste) for a 20" wheel. It's too bad because I have always loved the BBS CH-Rs, but the widest they come in is either 20x9 or 20x10.5. It's a bummer because I think the right 20" wheel looks amazing on an RS. I don't dislike my 19's and someone should probably talk me out of changing wheels, but a 20" BBS CH-R is one that I would ditch my Forgestars for.
    Convince me not to!!!
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Quote Originally Posted by 2008s4 View Post
    Evasive lists a 20x10 ET18 (http://www.evasivemotorsports.com/mm...ode=BBSCHR_TNM), but that offset might be too much for our cars. Could always do the 20x9 then just play around with spacers until you get your desired fitment as well!
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Oct 28 2016
    Central, CT
    Quote Originally Posted by b6bydesign04 View Post
    The 20x10 et 18 actually pushes the wheel out 1mm more than the 20x10.5 et25. If the right deal came up on the 9" wide ones I might jump on them. But until then I'll save the pennies for something else.
    Feb 23 2010
    Nebraska
    Hey sorry for the month delay in response...it’s hard to say really. It’d be a tight fit, regardless.
    My setup rubbed very rarely. I was, however, on adjustable coilovers, which obviously allowed me a little flexibility.
    Given you have that same flexibility, I would sure think you’d find the right setup which would give you a comfortable ride height.
    At the end of the day, 20x10.5’s just look mean!
    A couple more because I still miss her!
    ~ Matt J
    IG: @rsrtsvt
    '08 RS4 -- Suzuka
    Senior Member Two Rings thesecretkode's Avatar
    Jun 26 2016
    Boston, MA
    Will 20x10.5 et35 fit? I'm less worried about the fender as I am the inner rim to strut.
    Present:
    '07 RS4 - Mugello Blue
    '18 S5 Sportback - Glacier White
    '06 S4 25quattro - Avus Silver
    Dec 30 2009
    1995 Corrado / 2004 R32
    Vancouver, BC, Canada
    Quote Originally Posted by thesecretkode View Post
    I think it would depend on what width of tire you're running as well, but I would prob still want to run a 10mm spacer with that setup to be sure/safe for inner clearance.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by Marky G View Post
    I don't think he would be able to run a +25 on a 10.5 wheel. I'm on a 9.5 with a +26 and I'm right there on the fender.
    Nov 14 2005
    Charlotte, NC
    It's possible, the pictures @ad2330 posted above of his former car were with 20x10.5 ET25 CH-R wheels and 265/35/20 Hankook V12 tires.
    -Sean
    Dec 30 2009
    Exactly what I was basing my reply on. A few guys have run those CH-R's with great success with good lows.
    Feb 13 2018
    Anybody running similar setup 20x10.5 et25 on a b7 s4?
    Jun 26 2016
    Boston, MA
    Quote Originally Posted by Grey_gull_S4 View Post
    Looks like no one ever responded to this...
    There's no way you could fit that on a narrow body car. Did you end up trying?
    Present:
