Results 1 to 14 of 14
    Sep 04 2015
    Cincinnati
    Car cutting out when accelerating!
    Okay so I recently replaced the fuel pump and fuel filter about a month ago. On my way home today the car started cutting in and out when accelerating almost like limp mode, it idles fine though. Any ideas?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    cel flashing ?
    might be misfires
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Senior Member Two Rings lathdogg's Avatar
    Jun 01 2012
    Laramie, WY
    Coil pack
    2015 GTI S
    Sep 04 2015
    Cincinnati
    No check engine light flashing or anything. Can it still be coilpacks? I removed back seat and the fuel pump makes a kind of loud whine only when giving it gas.
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Quote Originally Posted by HopskinsS4 View Post
    I have same problem. But I have cam codes on both banks. My car is out of time. Doing engine pull!
    Sep 04 2015
    Cincinnati
    It's weird, it hasn't thrown any codes at all
    Sep 04 2015
    Cincinnati
    Any ideas on what to look for since no check engine light?
    Established Member Two Rings BOO$TedS4's Avatar
    Oct 06 2015
    96 jeep Cherokee sport, 95 Mitsubishi Eclipse GSX
    Williston ND
    Having the exact same problem any help would be much appreciated
    Established Member Two Rings pandapod's Avatar
    Feb 09 2014
    Connecticut
    I feel like a lot of us are having this problem lately. I had this for a little but honestly after I performed an oil change, this issue has been majorly reduced or at least no where near what i was suffering before the oil change. I did get a CEL when this happened and one code was related to the camshaft being over-advanced, and the second was in regards to the catalyst or cat converter. If I had to put money on it, I'd guess most of our issues related to this problem are due to clogged cats, however this is not something I will be attempting to solve.
    Sprint Blue Pearl B7 S4 with JHM IM spacers, K&N drop-in filter, 034Motorsports Density Line motor mounts, 034Motorsports sway bay end links
    Oct 06 2015
    Williston ND
    Quote Originally Posted by pandapod View Post
    I don't have cats lol
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    knock sensors gone bad?
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Feb 09 2014
    Connecticut
    Quote Originally Posted by BOO$TedS4 View Post
    damn, there goes that theory...haha
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Check your throttle body?
    Established Member Two Rings S4bro's Avatar
    Feb 17 2015
    Calgary, AB
    Hopefully you find the cause. Mine does that sometimes too. Hasn't thrown any codes.
