Results 1 to 21 of 21
    Senior Member Three Rings AngryQ5's Avatar
    May 05 2013
    15 Kia Rio Lx DD audi q5 2.0
    ny
    Power steering. loss of power steering
    So i have a 13 q5 2.0.
    All of a sudden the powers steering got really heavy. And yet drivable.
    Basic symtoms (*) from straight it will turn about 5 degrees both side without much problem. But after that it gets really heavy needing to use two arm force to maneuver.
    I was lowered on hnr springs and had flat bottom steering. Which non should really be the culprit. But had to take the springs off and put Oem springs so the dealer wont deny coverage.
    The dealer will take a look tomoro and let me know but any of u had similar problems?
    If i hadnt replaced the oem springs they would most likely deny coverage right?
    Sent from my SM-N900V using Tapatalk
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Sounds like the pump went out.
    Steve
    '15 SQ Monsoon
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    This might be our rack, I'm not sure. It has to be similar
    Steve
    '15 SQ Monsoon
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    I've had mine make some noise a time or two after it was pretty warm when turning- sort of like low fluid on a 'normal' PS setup. No failure yet.
    Steve
    '15 SQ Monsoon
    May 05 2013
    ny
    Mines havent made any noise nor previous signs. And according to my spring installer he said it was the whole rack and pinion...
    Waiting on the verdict from the dealer.
    Will report back tomorro ...
    By the way i just hit 40 k
    Jul 12 2014
    _
    Quote Originally Posted by AngryQ5 View Post
    This is the first time I have heard of this happening to the 2.0L Q5. Did you get a warning/alert/light on the dash?
    Good Luck and please share your experience with the dealership.
    Feb 24 2015
    12 Q7 Prestige SLine, 04 TL 6MT
    Berkeley Heights, NJ
    Over on Audiworld.com there are a couple of posts regarding a recall for 2014-2015 SQ5 power steering failures but this is the first time I am hearing about a problem on Q5's. More info here: http://www.thecarconnection.com/news...power-steering
    Did you get any warning messages on the dash?
    May 05 2013
    ny
    Quote Originally Posted by QUBE5 View Post
    Nope dash was clean no warning lights or anything.. im waiting on them to call me sometime in the afternoon
    May 05 2013
    ny
    Quote Originally Posted by will822 View Post
    I have seen that on the sq5s from previous posts but if i remeber correctly it wasnt much drivable? Cuz i seen them post pics of getting it towed.
    In my case it acted as if there was half or 1/4 of a power there, weird feeling..
    Will keep em updated...
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    you may have regular normal power steering. I just looked up your car in Mitchell repair and it shows both electro mechanical as well as hydraulic.
    Steve
    '15 SQ Monsoon
    May 05 2013
    ny
    Quote Originally Posted by Smittylube View Post
    I have no idea which one i have. To be honest when i opened the hood i did not see a PS reservoir. So i assumed i had electric but if anyone else who knows can chime in ....
    May 05 2013
    ny
    Just received a phone call from the dealer they said they fixed it and it was the steering shaft.
    SA did not fully explain the situation but all said and done under warranty thank god.
    I will post up pic of what was done and also for any 2.0 guys there was a recall on crank case sensor or something .. ill post the invoice later
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Yes others have posted about the u-joint in the shaft or the slip joint getting tight and binding. I would just have to think you should feel it coming on, but....................
    Steve
    '15 SQ Monsoon
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    what dealer did you go to? I'm almost at 44k
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    May 05 2013
    ny
    I get it serviced at biener audi in great neck ny. Never been to anyother places but havent had any problem there so far.
    May 05 2013
    ny
    Here is the invoice
    The second line is the recall
    Nov 08 2014
    '14 Quattro A4
    Santa Cruz
    Warrantee or OOP?
    Steve
    '15 SQ Monsoon
    May 05 2013
    ny
    Warrantee or OOP?
    Sorry pic got cut off everything is NC. Under warranty.
    Jul 12 2014
    _
    I'm glad to hear that they resolved this for you.
    May 05 2013
    ny
    Thank you... dilemma whether i should keep stock springs on or lower it back ....
    Leaning towards leaving it just stock all the installation costs are killing me ....
    Jul 12 2014
    _
    Yeah, I can certainly see those costs adding up. Personally, I've been waiting till I'm out of warranty or if VW is going to buy my Q5 TDI back. My situation is a bit different though, but you may want to wait a thousand miles or so to see how the repair holds up and then make a determination so you don't have to go through install and uninstall again if something was to happen with the repair between now and then... just in case.
