Results 1 to 8 of 8
    Jul 28 2013
    2017 Ford Edge Sport; 2004 Ford Exploder (as my wife calls it) V6, 7 passenger
    Rabat, Morocco
    black tail light retainer clip
    Just came back from a trip and my passenger side tail light is no longer secured on the inboard side. According to my wife the friend we gave a lift to forced the trunk closed - which apparently put enough pressure on the assembly to break the black tail light retaining clip. I went to Rockville Audi, because I prefer not to do business with Audi of Arlington (in October they told me my front brakes were down to 4 mm and asked me if I wanted to have them replace the brakes... the car had about 42k miles, I said no. Still driving around on the brakes no problem and when I popped into PepBoys for an oil change last week, they said it looks like the brakes have about 15% remaining). Anyway, asked the guy for the part and he asked me for the vehicles VIN number... so I went out to the car, took of the tail light, brought it in and showed him what I needed to replace. He then suggested I go out and get the VIN number so he can be certain which replacement tail light needs to be ordered (400$).
    I'm reticent to use duct tape on this (inside of course). Has anyone found a source for the clip? Should be a couple of dollars at most for the part.
    Thanks
    Mar 21 2015
    That's a hard read right there
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    You went to Pep Boys for an oil change! I still can't get over that!
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    What year is your car?
    Are you talking about an oil change?
    Are you talking about the tail light clip?
    Please separate the ideas so we can assist you better.
    /gets off high horse.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Jul 28 2013
    Rabat, Morocco
    2012 Audi S4 - tail light clip - should be the same for B8 2009-2015 - probably other models as well.
    It is the black U shaped retaining clip that holds the right (and I assume the left as well) inner part of the decklid portion of the tail light flush with the deck lid.
    The following is written on the black clip:
    Hella
    >PA-6F30<
    167016-00
    Maybe I need to search under Hella, looks like that could be the Slovakian manufacturer of the taillights.
    Not haven't a lot of luck finding the clip online. May start looking for someone with a cracked taillight who needs to replace the assembly.
    Clip probably costs 3 cents to produce.
    Jul 28 2013
    Rabat, Morocco
    This is the picture of the front of the taillight - not sure to connect links, still looking for the back -
    Item # 15802992 more details on - http://www.carid.com/2010-audi-a4-ta...-15802992.html
    Deactivated Two Rings
    Feb 07 2013
    Beautiful BC
    Why wouldn't you tell him your Vin #? It is much easier for them to look up parts and assist you that way.
    Jul 28 2013
    Rabat, Morocco
    I brought in the part - it doesn't appear that they sell the item separately. I would think it should be pretty easy to look up a part when the part, full of part numbers, is in your hand.
    Beyond that, this isn't a one off item, it's a taillight, same part for A4 and S4.
