    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    Unhappy Forge TIP won't fit. Cut it?
    There's no way in hell this forge turbo inlet pipe is going to fit. the end hooking up to the maf is about an inch longer than stock, nbd. but the end going to the turbo is about an inch and a half or so longer than the stock one. about a half inch or more too long to be able to clear the radiator or a/c or whatever fan on the lock carrier. Should I just cut about an inch off of it and try again? Is it normal to have to cut these?
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I had to cut my Forge TIP on the turbo end in order to get it to fit. I don't recall exactly how much i cut off but I think it was around 3/4".
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Strange that yours doesn't fit. Mine fits without any trimming.
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by fR3ZNO View Post
    Mine fit but it was pressing hard on the back of the headlight housing. By cutting a little off of the turbo inlet connection I was able to get the hose off of the headlight.
    Are you running the stock airbox?
    Feb 09 2013
    WNY
    Mine doesn't press on the headlight, but it definitely very close to it. Stock airbox too.
