Results 1 to 40 of 43
    Nov 19 2014
    California
    I started this thread asking for power module and downpipe options and recommendations and planned updating my original post with every finding. However it started becoming somewhat cluttered, thus I am replacing the entire post with a detailed feedback instead.
    _____________
    I leased my S3 in January 2016: loved the car, but wanted to add a little punch and enhance the exhaust sound which would be reversible at the end of the lease and sold. I ended up going with JB1, Audi Sound Enhancing kit, Bull-X Catted DP, modified stock air intake, aFe dry drop-in filter and 034Motorsport Dogbone Mount. It's been around four months since all the above have been installed and I would like to share my experience.
    The first and easiest modification was the Audi resonator delete kit. The sound was very good for a four-cylinder engine, a little raspy and brief buzzing noise around 3K RPM for several seconds, but I guess I was the only one to notice it :) From this point, I started searching for moderate performance gain options and after a couple weeks of research decided to buy a downpipe and JB1.
    I ordered the JB1, but because of the back order, I first installed the downpipe for which the Bull-X was the obvious choice for me as Emmanuelle Design is around 30 miles away and the price was reasonable at $1.200 installed. I must say that the quality is exceptional, however the one I bought WILL throw error codes without full ECU flush. They have another one for sale that guarantees error free functionality, which wasn't available at the time of purchase.
    With the DP installed along with the absence of resonator, the exhaust note became very loud at WOT, but I loved it and kept punching the throttle and enjoying the burble and farts. The raspiness still was there, but toned down. In terms of power gain with just the downpipe? I didn’t notice any. Most importantly, the exhaust note is very good. It's loud, but only at WOT, but it's very addictive and I love it as it became a little more refined probably because of carbon build up.
    I was expecting to see engine light right after the DP installation and was very excited when nothing happened while driving back home from the shop, but the check engine went off after 100 miles or so with P0420 code. Fortunately my friend has a mechanic shop and he is always there to help. We first installed the medium size Vibrant O2 spacer provided by Emmanuele Design which just delayed, but eventually the check engine went off again after around 400 miles or so. We scanned and erased the code, but needless to say that the check engine kept coming back.
    I finally received and installed the JB1 and was very pleased by the difference it made. The car became so responsive with dramatic power gain and much smoother acceleration even at lower RPMs – the hesitance is almost gone. I also was hoping it would help eliminate O2 error codes, but it didn’t. In fact, more codes started appearing. What was happening is that when I drove really hard without the traction control off, the car started behaving weirdly. The fuel cut off to the point that brought to limp mode with no boost at all. I even experienced abrupt power delivery with traction control completely off. On the other hand, everything was very smooth if the car wasn’t being pushed really hard.
    During the first several weeks I was very weary because of error codes and fuel cut offs at WOT. I started questioning if the [moderate] modifications I wanted to have were worth to go through all those annoyances, but I really liked the power and sound and decided to do everything possible in finding a solution.
    To get the O2 sensor related error code, we installed the largest spacer within the Vibrant kit and started monitoring the car’s overall behavior by scanning it regularly (you will find the history of the logs at the end of this post). It was apparent that the largest O2 spacer helped, but other codes, which I thought were related to JB1, made me worried. I switched to Map 6 on JB1, but it didn’t make much difference. I then asked for help on JB1 forums and George, at Burger Motorsports, suggested to lower the fuel loop to 25 with Map 1. I have access to 91 octane only, thus going above boost safety 4.8 is not recommended. After setting the FL to 25, everything is good now. I drove more than 1000 miles since the last scan without check engine light going off. Most probably, there are still pending codes, but the car defiantly behaves much smoother now. I only experienced one or two slight power disruptions at WOT, will scan the car in near future and update if anything.
    I also went ahead and modified the stock air intake by opening the driver side slots in the front of the intake and blocked the opening on the back right side. I then replaced the stock air filter with aFe Power 31-10254 Magnum FLOW OER Pro DRY S Air Filter. With this, I did notice a slight improvement in throttle response, but nothing big. The addition of 034 dogbone mount also slightly helped with overall low-end responsiveness with much crispier DSG shifts. It added a slight vibration when the car is parked or about to shift to Drive, but nothing annoying. I think it’s a very good little improvement.
    I cannot explain what has been happening with all the faults. Is everything caused by JB1, or the DP, or air intake modification, or the drop-in filter, or everything combined? I have no idea, but what I found out is that several of those faults might be thrown even on a stock car without any modifications and there are many factors and variables involved.
    I haven’t tracked the car thus cannot comment on how the JB1 handles heavy load. What I can tell is that it’s not perfectly smooth, but definitely a great power module. What I suggest, if you have a similar setup as mine, is drive smoothly. You can push as hard as you want, but do it in a more smoother manner.
    At the end, I really like the overall setup and definitely keeping everything. And I would like to ask you guys pitch in with your own input. Let me know if I missed anything or misrepresented something.
    VCDS Logs
    ____________________________
    Scanned March 28, 2016
    Milage - 3316
    2 Faults Found
    15058 - Fuel Rail/System Pressure
    P0087 00 [096] - Too Low
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 5112 km
    Date: 2016.03.24
    Time: 10:59:44
    18931 - Oxygen (Lambda) Sensor B1 S2
    P013E 00 [232] - Response too Slow Rich to Lean
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 4813 km
    Date: 2016.03.18
    Time: 23:46:51
    Scanned April 08, 2016
    Milage - missing
    3 Faults Found
    15327 - Torque Management Request Input Signal A
    P2545 00 [032] - Implausible
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 5877 km
    Date: 2016.04.07
    Time: 10:23:10
    P0087 00 [040] - Too Low
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 5880 km
    Date: 2016.04.07
    Time: 10:24:30
    21406 - EVAP Emission Control Sys
    P0441 00 [096] - Incorrect Flow
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 5531 km
    Date: 2016.03.31
    Time: 11:55:34
    Scanned April 15, 2016
    Milage - 3833
    1 Fault Found
    18932 - Oxygen (Lambda) Sensor B1 S2
    P013F 00 [096] - Response too Slow Lean to Rich
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 5999 km
    Date: 2016.04.10
    Time: 00:10:08
    Scanned April 18, 2016
    Milage - 4041
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 5999 km
    Date: 2016.04.10
    Time: 00:10:08
    Scanned April 29, 2016
    Milage - 4430
    3 Faults Found
    3 Faults Found:
    17178 - Databus
    U1123 00 [032] - Received Error Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Mileage: 7024 km
    Date: 2016.04.27
    Time: 00:03:10
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Mileage: 6618 km
    Date: 2016.04.19
    Time: 17:36:22
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 6725 km
    Date: 2016.04.21
    Time: 09:09:07
    Scanned May 28, 2016
    Milage - 5571
    2 Faults Found
    Freeze Frame:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 8019 km
    Date: 2016.05.10
    Time: 08:58:24
    Jan 29 2016
    FJ Cruiser
    N Tex
    Yegor, sorry I do not have any advice for you on the downpipe. I have the Neuspeed PM and APR intake and I am looking at the res-delete kit. Is there any performance benefit to the res-delete or is it strictly sound?
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Most downpipes with the res delete might be too loud. The awe resonated downpipe might fit your needs and it's also error free guaranteed. The only drawback is the price...
    I have the non-resonated version and I plugged some holes in the trunk to quiet loud dsg farts down.
    -cW
    2023 X3 M40i Alpine White
    Nov 19 2014
    California
    Quote Originally Posted by TWS3 View Post
    Oh no, it just enhances the sound, no gains at all.
    Nov 19 2014
    California
    -cW
    Thanks coolwater! A forum member on Vortex provided the exact same feedback on AWE. He will be installing CTS DP and hopes a spacer will prevent throwing CEL. We'll see how it goes.
    I will definitely go with resonated regardless what brand I'll choose.
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Quote Originally Posted by YegorS View Post
    I have the JB1, MST intake and unitronic DP. The uni is a quality piece it is catted and will through a code experimenting with vibrant spacer and jets to see which works best cel came back after about three weeks with the middle jet going to try the largest one.
    It is a little loud on cold start but otherwise ok. But I am coming from an open ewg STI
    Nov 17 2014
    San Francisco, CA
    I have the USP catted DP, AWE Exhaust and JB1 on my A3 and to me, only difference between all the DP's is the type of high-flow cat used if going with that version. If not going for catted, they literally are all the same. USP just happened to be the cheapest and the build and weld quality is what I'd expect, top notch. The DP will make a dramatic difference in the car's output. The JB1 takes advantage of the better flow. I really couldn't be happier and for non-resonated system that I have, its loud when the revs are higher, but at under 2500 its pretty normal-ish. Above that and it gets fairly loud but not overbearing, however i'm usually never outside the car to know :-P.
    Nov 19 2014
    California
    Quote Originally Posted by 2015S3 View Post
    Uni DP is almost $1,000 and the AWE is just $300 more. I would buy the latter if I went that price range: Why did you choose the Uni over AWE?
    Dec 21 2015
    Melhbach, Germany
    B & B also makes a DP that is affordable, catted, and the reviews state it isn't very loud which would be a plus due to your resonator delete. They are high quality. If any DP throws a codes its a simple $40 dollar CEL elim fix and I'd toss one on no matter what for peace of mind no matter which DP you pick. For the price of the AWE DP your could buy the entire B & B Turbo back....
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    The BB downpipe did not get good reviews on the golfr. Basically the fit was very poor. The flange mount on the turbo side could not be mounted flush and caused exhaust leaks. One golfr owner went thru two seperate BB downpipes to try and make it work. Cost him more in labor than the money saved on the part.
    -cW
    Feb 11 2015
    New Jersey
    I got the uni for $400 with 1000-miles on it, that's why. LOL Quality is amazing and all v-band fittings with metal gaskets (No-Leaks).
    you have to be careful installing, follow the directions exactly as they have them, the OEM DP bracket is a bitch if you do not follow the instructions.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by reyoasian View Post
    so yours is non-resonated and catted?
    Yes and yes. It is perfect now with the extra sound dampening.
    -cW
    Sent from my SM-G900V using Tapatalk
    Nov 19 2014
    California
    Of-course, $400 is a steal :)
    Nov 19 2014
    California
    I decided to go with either AWE or Bull X, don't want to deal with spacers, etc. As we all know, AWE guarantees error free for their product. How about the Bull X, guys? Which one would you go with and are there better options within that price range?
    Nov 19 2014
    California
    I'm having Bull X installed by Thomas at Emmanuele Design next Monday, will keep you guys updated.
    Aug 06 2012
    san diego
    look forward to the review!
    Feb 18 2016
    Infiniti QX60
    SD
    After looking at all the down pipes, Bull X will be the one I go with.
    Sep 17 2015
    long island
    Does bull-x offer no CEL light as well?
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by mikeyhandz View Post
    Their latest version has an exclusive HJS cat, which is nicer than the old one(old was still good), and to my knowledge, no one has had a light with those older versions. Emmanuele Design will be installing the new version next week, so I can report back. I'm going to put on a spacer, but if it throws a CEL, I'll flash it down the road. *shrug*
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Nov 19 2014
    California
    Just updated the thread guys, read the post on the top.
    May 13 2008
    MQBs
    San Francisco
    Thanks for posting your review, mine goes on in the morning, can't wait!
    Nov 19 2014
    California
    Quote Originally Posted by Kookie View Post
    Let us know what you think. It can be very loud with res delete :)
    Oct 01 2015
    Karachi, PK
    i got Revo catless downpipe, will install this weekend
    2015 A3 1.8TFSI 7speed S-tronic (FWD)
    Engine mod BMS JB4/ Revo catless DP/aFe dryflo drop-in/stock intake mod/Revo MQB Intercooler/Revo muffler delete/CTS TIP/GFB DV+/034 dog-mount ......VCDS mod visual parking aid, needle sweep & oil temp on DIS
    Dec 21 2015
    Melhbach, Germany
    Good Write up. Get back about a thousand miles or so later to see if anythings changed.
    I'm also in the same boat of either AWE resonated or the Bull X. Leaning toward the AWE since I'm wanting the AWE Track Cat Back which I'm pretty sure would be too loud wo/the resonator on the DP. I'm also going to be running the JB1 at 1k miles and until I get all the other mods then going Giac Stage 2 once my car hits 5k miles to be sure I don't have any issues out of the factory.
    2012 SRT8 (Sold)
    2006 Z06 (Sold)
    2010 GT500 (Sold)
    Nov 19 2014
    California
    Spoke too soon :) It threw error code today, after around 100 miles, P0420. We reset and will continue driving without spacer, Thomas gave one just in a case. Then, if it throws code again, I'll install the spacer.
    Dec 21 2015
    Melhbach, Germany
    Easy fix. Bull X description didn't say anything about being CEL Free. Only DP that states that is the AWE, and your gonna pay for it. I'm on the fence between the 2. Not planning to add my DP until I get the Stage 2 tune. Gonna add both at same time.
    2012 SRT8 (Sold)
    2006 Z06 (Sold)
    2010 GT500 (Sold)
    Nov 19 2014
    California
    Quote Originally Posted by Blaine View Post
    Yes, of-course, they never promised error free functionality.
    Nov 19 2014
    California
    Three days with the downpipe and I still love the sound, but – with the res-delete – it is very loud and buzzing on full throttle. I wonder if the factory muffler causing the buzzing.
    In the previous update, I stated that I will not touch the Audi res-delete, but because it is too loud and kind of buzzing/raspy under full throttle, I am now interested in finding out what can be done to make it a little quite and get rid of the buzzing and raspy noise. Will ask Thomas and share his input. I love how it sounds under low RPMs, but it's too much for me under WOT.
    Active Member Two Rings Workflow's Avatar
    Jan 19 2016
    1967 pan up
    Southern Cal
    In the previous update, I stated that I will not touch the Audi res-delete, but because it is too loud and kind of buzzing/raspy under full throttle, I am now interested in finding out what can be done to make it a little quite and get rid of the buzzing and raspy noise. Will ask Thomas and share his input. I love how it sounds under low RPSs, but it's too much for me under WOT.
    Have you looked into a Vibrant resonator? More than affordable and easily sourced from a good muffler shop (given you don't have the OEM unit).
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Plug some holes in the trunk with insulation. It will quiet it down. This is how my setup sounds now.
    https://www.youtube.com/watch?v=yA0D7NXxOBo
    -cW
    Nov 19 2014
    California
    -cW
    I read your posts coolwater, but I don't want it to be that loud at all, not just inside.
    Nov 19 2014
    California
    Quote Originally Posted by Workflow View Post
    I just checked them out: they have several options and the quality looks good, will definitely consider.
    How about guys, installing the stock resonator back, will it defeat the purpose of the DP? I looked inside it, it doesn't look like it will restrict the flow.
    Oct 01 2015
    Karachi, PK
    u will still gain some power due to restricted oem catted DP, resonator delete add couple of more power or maybe not and ofcourse more sound. keep stock resonator for not making loud
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by slick99 View Post
    Simply put, if the inside diameter is the same, no.
    Nov 19 2014
    California
    I will probably try installing the stock resonator back and listen to the tune :) I definitely don't like the raspy/buzzy sound I have now.
    Apr 08 2015
    United States
    I have the bull x downpipe with the high flow cat they provided. When I was stage 2, the check engine light would come and go. Ive taken the flash off and again, its comes ane goes as it chooses. I put in the recommended spacer and that hasent helped yet. Annoying but I can live with it.
    Oct 01 2015
    Karachi, PK
    Quote Originally Posted by eddiebarber View Post
    Do u feel power loss when CEL come?
    Sent from my HTC One_M8 dual sim using Tapatalk
    Nov 19 2014
    California
    Got a CEL today again. We installed the spacer, will report back.
    Apr 08 2015
    United States
    Slick99, no power loss. Car always feels the same. I've read here a few times intake and/or a downpipe provide no power without some kind of ecu flash or some supporting mod. Now i could be wrong but I believe i feel some extra power from my intake and downpipe with no flash. Just a thought.
    Feb 12 2016
    La
    Hey OP , I'm in the same boat you were in.. Any updates recently?
