Hi,
I went to get my V8 S4 remapped and some pre-checks were done. Turns out that my car has some issues with the 'Timing Retardation' in Cylinders 1-4 (mainly 2 and 3). I'm not good when it comes to engines so I was wondering if anyone can help. I was advised to change my spark plugs, fuel filter (Mann one) and to use Wynns injector cleaner. I normally run Shell V power but I've used Tesco 99 RON for about 200 miles now and can't feel any difference.
The previous owner had a map put on and had the top end rebuilt in March 2015. Some people have said maybe too much of the head was skimmed off?
Does anyone have any advice to give? The person doing the map is saying any time he does anything engine wise the ECU 'corrects' the Cylinder Ignition Angle Delay to 9.5 (and on a recent run 11.3!).
All pulls were done in 3rd gear from approx 1.5k RPM -> Redline. Audi S4_LOG was done when I went to get the map done, LOG-01xx was done after the spark plugs and fuel filter was changed. Any advice would be greatly appreciated.
Attachments can be downloaded below, I don't have permission to attach to post:
Audi S4_LOG
LOG-01xx
Update after fuel filter change and injector cleaner put through car: The car is running around the same MPG as before but now you can smell the fuel burning much richer. Also there is a lot of unburnt fuel being pushed through the exhaust - when I look at the exhaust tips there is lots of fuel splatter around the inside edges (being pushed out but not burnt).
Work done on the engine in March 15:
https://www.dropbox.com/s/ht43ubwaz4...35.08.jpg?dl=0
