Here we go again, i know that there's alot of these threads around on the internet, But i feel like i did alot of the stuff People did to fix it /-:
The engine sounds alot like a DIESEL, even tho it's a 1.8T gasoline engine.
It hasen't lost power at all, it just sounds like a diesel, and the Oil pressure turns out waaaay too low.
Oil pressure test : 0,2 Bar at 900 RPM
Oil pressure test : 1,5 Bar at 2500 RPM
It should be waaaay higher ( as i remember 2,0 bar at 900 RPM and 3,5 at 2500 RPM ) correct me if i'm wrong, can't exactly remember the DATA.
The following parts have been changed ( the most Common parts mentioned on other threads ) :
-Oil filter
-Oil 5w-40
-Oil pump
-Oil Pan
-PVR ( Pancake valve )
-PVR hoses cleaned ( Seems like it's alittle rusty? )
-Oil pressure switch ( the one at the oil filter )
The car has got Oil chance 4 times since the last 1,5 months ( Cause of different additives, trying to fix the problem )
Following additives has been used :
-Würth Oil additiv
-CRC Motor flush
-Würth gasoline additiv
-Valve cleaner additiv
Some guy told me that It could be the Oil pipes inside & outside the engine. He told me They could be rusty caused by engine NOT bring run for a long time (Just to mention, the car was standing still 1 year before i bought it)
It's hard for me to belive that the problem is the mentioned above, seems so unrealistic?
The engine fault codes are :
16712 - Knock sensor 1 - bench 1
16395 - Intake camshaft position - bench 1
17733 - Something with ignition ?
17735 - The same as above with different bench
16717 - Knock sensor 2 - Bench 2
They were all deleted after diagnosis.
The Oil sump has been cleaned 2 times now, seems fine tho.
Any clues at this point ? I'm running out of hope for this engine to run correctly again )-:
