Results 1 to 8 of 8
    Feb 22 2016
    Cleaning out my EVAP System -- Engine Flood @ Gas Up and Stuttering on Turbo
    So, I'm pretty sure my EVAP system needs a good solid cleaning.
    Here are my symptoms:
    • When the turbo spins up really high, my engine stutters. It doesn't misfire (no misfire code) but it definitely chokes.
    • When I gas up sometimes, the car won't start for up to 10 minutes
    • I have an EVAP Insufficient Vaccuum code on my reader
    Reading around, I'm thinking that this could be primarily due to having a very dirty or perhaps even malfunctioning purge control valve. I'm planning to disconnect it this weekend and give it a good spray down and cleaning with Brake cleaner. My thought is that my car either can't suck in enough air or can't expel the fumes fast enough when the turbo kicks way up and it chokes itself.
    Does this sound like a sane cause for my symptoms, and a sane solution? Any other input?
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Can you delete the system? Does your state allow that for inspection?
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    Quote Originally Posted by exallium View Post
    My understanding is your purge valve only releases gas vapor from your gas tank. I don't think it would cause an issue such as you are experiencing. You can leave the EVAP system completely disconnected and it will only throw a code, not cause your car to run funny.
    Your engine does not pull much air from that line, only when it is purging does it suck in the fumes. So it would not be robbing the engine of any air. Your turbo is not connected to the EVAP line. Your EVAP only connects into the suction side of your turbo, so your turbo would not have anything to do with it.
    I actually just found today that I had been driving with my EVAP system plugged (I had my check valve in backwards) for 3 years and I did not notice anything other than the code.
    EDIT: You may have a vacuum/boost leak. Did you recently do ANY maintenance to your car before you noticed this issue? Also do you have any modifications done to your engine?
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Oct 21 2005
    y
    To test. Unplug the evap and block the hose that goes to the intake.
    A leaking evap would flood engine at lower rpms. I've seen them vary from rough idle to stalling. Not sure how it affects boost.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    The Evap system only works under certain load conditions, boost is not one of them. It is really only at idle or stead cruise that the EVAP system works. A "leaking" EVAP is the same as unmetered air entering the engine, so stalling and idle hunting can be normal symptoms.
    Your issue under high rpm (I assume that is what you mean by turbo spins up really fast....) is most likely a misfire, might just be soft enough to not set a CEL. Coils and spark plugs are the most common culprits for boost misfires.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Feb 22 2016
    Quote Originally Posted by Davdraco1 View Post
    I'll have to check provincial guidelines.
    Quote Originally Posted by Spectre1130 View Post
    We did a complete engine swap about a year ago. The only mod I can think of is that I have an aftermarket boost meter attached into the lines.
    Maintenance was only after I started noticing the issue. I swapped all of the plugs a few weeks ago. Haven't done the coils yet.
    Quote Originally Posted by Wrath And Tears View Post
    Gottcha. So it's probably a bad coil. It's too bad it doesn't set the CEL =P However, I do think that piston 2 misfired at one point and we swapped in a spare coil we had on hand off the original engine.
    Maybe my first step is to replace P2 coil with the new ignition coil sitting in my trunk...
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    The evap system still pulls vacuum under boost through the tip.
    I suggest the OP tests his check valves, easy enough just blow through him. The hard warm start may also be due to a faulty CTS.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jan 08 2012
    2015 VW GTI
    Which coils are you using? The old style or the new style? I found my old style on the AEB were junk.
    If you changed your plugs, you may have too large a gap and could be seeing "spark blowout" when you hit higher boost. The higher psi in the combustion chamber can prevent a spark across a wide gap.
    EDIT: You can also pull your spark plugs and see if one is being blackened by a poor burn. That will help to determine if you a misfire too.
