Results 1 to 9 of 9
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Vibrant 02 Cheater after three weeks get a code P2270 Too lean, which restrictor use?
    I installed the catted Unitronic like 3-4 weeks ago installed vibrant 02 sensor and got a code today.
    I have a smaller and larger restrictor, which do I use?
    Oxygen Lamda Sensor Signal B1 s2
    Fault Priority -2
    Fault Frequency -5
    Date 2-12-16
    Time 7:41:08
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by 2015S3 View Post
    Fault Priority -2
    Fault Frequency -5
    Date 2-12-16
    Time 7:41:08
    I'd try the restrictor that will let less gases thru.
    Not sure if that is the smaller or larger one.
    -cW
    2023 X3 M40i Alpine White
    Oct 30 2012
    Arizona
    Fault Priority -2
    Fault Frequency -5
    Date 2-12-16
    Time 7:41:08
    BTDT...
    Okay..
    Are you stage 1 or stage 2?
    At sea level or there about you will use the thinnest spacer.
    Do you have spacers in both 02 sensors?
    Only asking because I went through this for 2 weeks trying to figure out what was tripping this code on my car too.
    The 2nd 02 spacer was the culprit. At Stage 2 GIAC all 02 spacers are removed.
    Feb 11 2015
    New Jersey
    Quote Originally Posted by A20V200 View Post
    BTDT...
    Okay..
    You mean the smallest jet, the spacer length does not change
    Oct 30 2012
    Arizona
    In the vibrant kit you should have 3 jets. The "openings" are small - medium - large. Use the largest spacer/biggest opening ..sorry for the confusion.
    Feb 11 2015
    New Jersey
    Thanks just did it that's what George said also
    Feb 11 2015
    New Jersey
    Error free since I put the larger jet in, nothing on the Vag. Lets see what happens.
    Oct 30 2012
    Arizona
    Good news...that should be the end of it hopefully.
    Feb 11 2015
    New Jersey
    Nope not the end of it, CEL back on after a few weeks, doing out to read code now.
