Results 1 to 12 of 12
    Feb 22 2016
    Phoenix, AZ
    Grinding noise around serpentine belt area. Video included, Please Help!
    First off, I want to thank the community for all the information that you guys post online. It is very valuable, and as I start dabbling with DIY work on my A4, I will try to contribute as well.
    My car started making loud, irregular metallic noises from the front end. When I inspected it, I found that the belt was cracking, so I replaced it (without removing the bumper, thanks to the tips on this forum).
    But, the problem didn't go away. I read and listened to many videos that others posted, but still not sure if it is alternator, AC or something else.
    Here is a video of the noise, any guess as to what it could be? Another interesting bit is that AC is not cold anymore, although the fan works; also, the noise does not change if I turn AC and Fan on or off.
    https://www.youtube.com/watch?v=6nNul2QsRJw
    My next step is to take the belt out and run it to make sure its not an issue with timing belt, etc. Thanks in advance.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    You said it was a metallic noise? Not sure what it sounds like when a bearing is going out (either in the alternator or ac compressor).
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Feb 22 2016
    Phoenix, AZ
    Quote Originally Posted by JDillon15 View Post
    its certainly metallic, please watch the video if possible. It doesn't sound like clicking noise that some people posted about when the alternator goes out.
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by audiCarMan View Post
    I listened to it and wasn't sure. Can you identify where it's coming from?
    Mar 29 2014
    Hampshire, UK
    Could be the belt tensioner...
    Does it get worse when you rev or its out on the road?
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jun 27 2011
    If you start the car with the Accessory belt removed completely (or just take all the pressure off the tensioner) does the sound persist? If it does, then your sound is likely timing belt or internal engine related. If it goes away then its something on the accessory belt like the PS pump, AC compressor or a bearing or the tensioner itself.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 22 2016
    Phoenix, AZ
    Quote Originally Posted by jkwelsh View Post
    It gets worse if I rev it.
    - - - Updated - - -
    I will try to do that tonight and post the result.
    Senior Member Two Rings Gotpsi2008's Avatar
    Mar 24 2015
    YFZ 450, Beer Fridge
    Sebago, Maine
    Take the belt off again, grab both idler pulled and see is they have any play at all, it sounds like one of the idler bearings let go. Every idler pulley should spin free and almost completely silent.
    2008 A4 S-Line Grille 2.0T 6MT Quattro | JHM Stage 2 93 | Autotech HPFP Internals | JHM 3" TP | OBX 2.5" DP | JHM LWFW | RS4 Clutch Pressure Plate Combo | 034 Motor Mounts | 034 Snub | 034 Density Trans Mount | Red Top Coils | AFE Pro Dry S | CTS Silicon Turbo Hoses | ECS Intake Boot | P3Cars Boost Gauge | BSH PCV Revamp | EBC Reds | Ziza
    Feb 22 2016
    Phoenix, AZ
    Quote Originally Posted by Gotpsi2008 View Post
    It goes away when I disconnect the belt. I rotated all the pulleys, and there was no significant play in any of them. but, the AC pulley has slight friction and makes a faint noise when I rotate it. Also, worth noting that the front side of it feels like a plate that can move, I am not sure if it is normal or not; see the video of it here:
    https://www.youtube.com/watch?v=dtjauXtW3PI
    If that is normal, what I am thinking is to get the bumper and radiator off, and them listen to them carefully, should be able to isolate easily that way. Please let me know your thoughts.
    Feb 22 2016
    Phoenix, AZ
    An update on this - I got the bumper off and put the radiator in service position to get a better look at the source of the noise. When I put the belt back on, it is what I suspected - AC Compressor. The noise comes when the front plate on the AC pulley pulls in (see video in the last post).
    Now to call around check what the labor would be to replace it. Even though it looks easy to replace, I am not sure how to pull the freon out; will see if a mobile shop will do it, driving it with it making such a loud noise is painful.
    Mar 24 2015
    Sebago, Maine
    You could drain it into the atmosphere and then recharge it later, buuuut I would highly recommend taking it to a shop get the freon drained, doesn't take long at all, then drive it home, replace the AV compressor yourself to save some coin, then bring it back to have them recharge it. I haven't really looked into our compressors very much but I do know some make out there have a replaceable clutch pack and all you need is a puller to get it off(your local autoparts store should carry one). But then again it all depends on what failed, easiest route would be to replace the entire thing
    - - - Updated - - -
    And if you do drive it home without any freon, pull the Ac relay just to be safe
    Jun 27 2011
    First off, I want to thank the community for all the information that you guy...
    Our AC unit has a swash plate setup so it can properly work with the variable load ac system we have. You can't replace the clutch pack because there isn't one, however I remember seeing someone rebuild their ac unit a while back. They pulled the wheel off and were able to replace a bearing or two on the drive shaft and that solved their problems. You'll likely have to remove the compressor and discharge the system but any ac shop can do that.
    I'll see if I can find the link and post it up.
    -CP
    2017 Q7 3.0t
