Results 1 to 6 of 6
    Dec 03 2013
    us
    My friend fucked up. What now
    So I was doing a routine spark plug change and while I was doing one side my friend was doing the other. Not till after he got done did he admit that he may have used anti seize instead of electrical grease. Should I just try to get as much out as possible from the coil pack and what would be best for cleaning them out?
    Thanks and from now on no more help from friends :/
    Oct 27 2011
    TOYS
    Philly Suburbs
    Spray the coil plug boot out with MAF cleaner.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Laughing cause I could totally see this happening.
    Best of luck cleaning it out.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Jul 04 2012
    Woodbridge, VA
    Were you using anti seize on the plugs and that is why it was laying out? I wouldn't put antisieze on plugs as it can change torque specs. If you are torquing them to spec you won't have issues not getting them back out.
    Dec 03 2013
    us
    Yea I have always put a small dab on and thanks I actually did use some may cleaner. Had some misfired under boost but they went away after a 5 minute drive oddly enough
    May 16 2008
    WA
    your friend... it's ok to admit your mistakes, no need to blame imaginary people
    As others have said, spray it out with electrical or maf cleaner. You can swap the bulk out by twisting up a paper towel or even using something like a q-tip. At the end of the day, nothing will be permanently ruined.
