Results 1 to 6 of 6
    May 13 2008
    MQBs
    San Francisco
    VAG help with 2015 S3
    Hello,
    Just switched over from a B7 and i've found there are a handful of small features I'd like to adjust on the new car.
    Can anyone help? Tried this with a friend's VCDS, but it wasn't licensed so it won't work on the MQB (8V) platform.
    I have the entire day, and I can drive to you. Would love to get this knocked out!
    Examples of what I want to do:
    Deactivate Wink
    Windows Up Auto/Rain
    Alarm Beep off/Chirp Only
    Etc
    Just some easy stuff I can do in a few minutes. If you need more motivation, I have adult access to money & beer
    Best,
    Harth
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    Quote Originally Posted by Kookie View Post
    Hello,
    Deactivate Wink
    Etc
    Best,
    Harth
    if ur ever in the OC area let me know
    i just did this for Jimbos5 (he has an 8v s3 also)
    killed the wink and all that other fun stuff
    hit me up anytime 657-215-5321 text prefered
    2018 TTRS
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by sirsycott View Post
    Thank you sir :)
    Active Member One Ring slam1979's Avatar
    Feb 01 2016
    Orange County, CA
    Hello great fellows. I am not sure I am going by the right protocol here as I am new. So I apologize in advance.
    I have a 2011 audi A5 Cab. I live in Costa Mesa, Ca.
    I am currently experiencing a "Headlight Range Control Defective" error on my car, and I was really hoping that I can find someone with a VCDS to scan my car for any sensor issues. I received the error when I tried to diagnose a faulty headlight bulb, by switching the L/R bulbs, and L/R ballasts. I believe I may have switch the light on when one/both of the headlight assemblies was disconnected too, causing the headlight range control error to trigger immediately after. I had no idea that it would mess things up. I have scoured the internet for an entire week on what are the possible causes and solutions. I am hoping that the VCDS only needs to re-learn the range control data and all can be well. I am willing to pay for the person's time, or even bring a case of beer (or whatever you like) as an expression of my gratitude.
    I have been also having the occasional "low battery warning", so hopefully the VCDS can provide insight on that too (but that is not my main priority right now). It would suck if I had a battery issue, or some short circuiting in the wires that's causing my bulbs to fail.
    2011 Audi A5 2.0 TFSI Cab FWD, 79k miles
    Mar 21 2015
    Quote Originally Posted by slam1979 View Post
    Just start a new thread in the so cal region section
    Feb 01 2016
    Orange County, CA
    Thanks so much. I tried to post before but i guess i wasn't given the privileges to start a new thread. After reading your message, I checked again, and I am able to do so now. Thanks again.
