got the car last feb.
so had the car for a year now
and now finally got the jhm tune
setting up the vpn and the cheetah cable wasn't bad
even tho there is a lot of steps but it all went smoothly
if you can read a cook book... then you can cook (one of my engineer professor would say that a lot)
so... if you can read the instructions... then you can tune your car
the tuning part went really smoothly with no errors or problems at all
I used at 15amp battery charger
JHM recommends a 40amp, but as i reed through some of the post on here some people did well with just 15amp
as for the tuning process it took about 25ish minutes
then after that did the on/off with the car ignition stuff
then it was drive time!
at first it felt like learning how to go from N to 1st gear all over again, haha
im getting use to it
