Results 1 to 40 of 51
Thread: HPFP Stud Kit
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    HPFP Stud Kit
    For those who have purchased the hpfp stud kit, is it possible to measure the length of the stud? I am led to believe that this is a 80mm double sided stud with thread m6x1, 27mm thread on each side. Really dont feel like ordering online.
    Shopping List:
    NUTS - pack of 5
    STUDS - pack of 1 (more durable), or STUDS - pack of 5
    the
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Feb 15 2016
    Cambridge,Ontario
    I was wondering exactly the same thing . LOl I just logged on to ask the same question. I was gonna take one of the existing bolts with me to my hardware supplier to make sure I get the correct thread pitch, but did not have the overall length. Too long and it would be very awkward to get on ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jan 24 2013
    Chicago
    I actually counted the threads on one of the kit pictures and since m6x1 each thread is 1mm. It actually turned out to be 27 threads. So im thinking 99% this is a 27mm threaded on both sides with 80mm overall length. Its a fairly common fastener.
    http://www.mcmaster.com/#93275a019/=118jjrx
    edit, OK so i believe I have the correct stud there. Since the HPFP bolt is a m6x60, and you cross reference this picture
    It looks like the stud is sticking out an additional 2cm past the HPFP.
    Sent from my SM-G920P using Tapatalk
    Feb 15 2016
    Cambridge,Ontario
    That's some good sleuth work I was looking at the same thing. I don't know how far the stud goes into the aluminum and if it bottoms out.
    I'm sure eventually someone will chime in with an exact measurement. If not I can always take the bolt off , measure the depth to bottom it out add the thickness of the pump and then 20 mm. I think you are right though 80mm is about right . but not a big deal to grind off a piece if its too long. I usually spin a nut on first , grind off a piece then spin the nut off to repair any thread damage, then put that end in the housing with Loctite . Proper length up front is always preferable though.
    1976 Yamaha XS 360
    Jan 24 2013
    Chicago
    The stud bottoms out. Put no preload on it but install it with some loctite. Some people have used blue, some red. I'll probably use red. The oem bolt length is 60mm 100% I'd honestly prefer to go to the hardware store pay $10-15. Don't know why aftermarket retailers are selling these kits; if they were some custom studs fitted exactly for the length of the HPFP i would understand. Also, there doesn't seem to be any reported issues in taking off the hpfp with these longer studs.
    Feb 15 2016
    Cambridge,Ontario
    agreed , exactly my thinking , easy enough to go buy 3 studs and 3 nuts , I was gonna use blue , but if they back out use red . I think the nuts are only 7ft/lbs or so so Blue should be fine. I think I'll do it April/May time frame as its too cold right now so lots of time to get what I need .
    Understandably the kit provider is reluctant to provide stud dimensions but I don't see the big deal really.
    1976 Yamaha XS 360
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    make a DIY and shopping list
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    good info and links in this thread...
    http://www.audizine.com/forum/showth...s-to-the-studs
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Feb 16 2015
    Awesome post guys,
    I think I am going to go with these
    3X: http://www.mcmaster.com/#94560a060/=118l07v
    3X: http://www.mcmaster.com/#93275a019/=118jjrx
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Jan 24 2013
    Chicago
    Get these nuts, or just go to your local hardware store.
    http://www.mcmaster.com/#94235a080/=118laf7
    comes in a pack of 5. The goal is to get as cheap as possible; you could even use a fully threaded rod instead of a double sided stud.
    Nov 15 2011
    Montreal | I sell in USD
    I was told by a tech that we should change our hpfp bolts everytime we replace our cf. If there is any truth to that it makes the stud kit make even more sense.
    Next time I'll put Lamborghini Aventador screws
    *****I sell in USD*****
    Feb 16 2015
    Quote Originally Posted by Denio24 View Post
    Probably just going to tack them on to a work order so I would prefer the rust resistance (that .0005" plating wont last too long on the bottom side). For a personal order I would get the Cadmium-Plated.
    Jan 24 2013
    Chicago
    Quote Originally Posted by Axis View Post
    The only reason I am even considering changing out to some studs is to make installation of the pump easier.
    Feb 15 2016
    Cambridge,Ontario
    yeah those Carr ones are the ones I was looking at too . Surprisingly difficult to get where I live actually. Hopefully I can get some shipped to Canada without the use of UPS brokerage thieves.
    if I find they are too long so I cant get a socket on im cutting them a bit shorter. we will see.
    nothing like a mod for a mod.
    The way things typically go for me I will be so excited about this mod I will get it all done and forget to put the new cam follower on
    1976 Yamaha XS 360
    Sep 06 2013
    Dublin, CA
    Then you shouldn't do it :) plenty of comments out there saying its a bitch to get up over the long bolts and you cant fit a socket over.
    Kristian
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Copen-cisco View Post
    If you have the softline hose, its pretty easy to just extend it with a longer piece from a hardware store, and deep sockets for the bolts. Shouldn't be any issues after that.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 15 2016
    Cambridge,Ontario
    well Carr would not ship to Canada so i'm getting a threaded rod 1 meter long for 8 bucks . A4 SS. The advantage of this is I can measure up and get the exact length so i'm not going way past the nut. Just have to be a little careful lifting the pump of so you don't " shave" the aluminum bore for the holes with the steel rod while removing pump . I think it will be fine though . Then I can cut it just above the nut by about 3 or 4 threads and have it look neat. I should have enough steel rod left over for a couple more cars lol.
    I have a buddy with an A4 so I think I know where the rest of the rod will be going.
    1976 Yamaha XS 360
    Jan 24 2013
    Chicago
    Feb 15 2016
    Cambridge,Ontario
    you got those already ? wow that was fast !! were they in fact 80mm overall ?
    1976 Yamaha XS 360
    Jan 24 2013
    Chicago
    I had to pick up some other things for work as well as this. And yes mcmaster is quite fast. I can order in the morning and ups will deliver same day, although this time i used will call.
    Mar 24 2013
    Oakdale, CT
    I have the banjo bolt and it's quite easy to get the pump off over the studs. You can also fit a deep 10mm ¼" drive socket on the nuts. It's tight on the bottom one closest to the firewall, but it's doable.
    -Adam
    Sep 06 2013
    Dublin, CA
    I was worried about the bottom one closest to the firewall but if you say it works
    I might do it eventually
    Kristian
    Account Terminated Four Rings
    Oct 15 2013
    Jan 24 2013
    Chicago
    While the studs may seem like a good idea, i was not able to fit the pump on even with the studs as short as possible. Tried it today with no luck.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    What do you mean not fit it on?
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Jan 24 2013
    Chicago
    I could not get the hpfp on all three studs.
    Dec 23 2011
    Is the hard metal coolant line in the way?
    Jan 24 2013
    Chicago
    Yes
    Jan 24 2013
    Chicago
    The kit is meant more fore gtis with transverse setups.
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    I was waiting for you to post pic how to put the pump in with the studs. I guess you're like me I put 3 studs in but couldn't get the pump in also the coolant hard pipe is in the way. Try to unscrew the hard pipe screws see if you got more room. I'm going to attempt again when weather is warmer. I also ask aluthman how he put his in and he say the pipe didn't bother him
    Sent from my SM-G900T using Tapatalk
    Jan 24 2013
    Chicago
    Cause he has a banjo bolt pump
    Mar 24 2013
    Oakdale, CT
    True, but the coolant hard pipe has never given me any issue. I'll snap some pics in a few days when I disassemble everything to swap in my new engine.
    -Adam
    Oct 01 2014
    Audi Q5
    chicago,il
    I too have banjo bolt. Just that pipe in the way. Maybe loosen the screws on hard pipe to move it around? Post some pic when you assembled your motor.
    Jan 24 2013
    Chicago
    I'm sure getting the hard pipe to move a bit would definitely help. For me it was the hose barbed fitting that was in the way. Other than that I'm fairly sure I would have been able to fit it in.
    Mar 24 2013
    Oakdale, CT
    Yes, you have to remove the two screws that hold the hard pipe to the manifold. Then move the coolant pipe towards the coolant expansion tank. I guess I just assumed every one did this already. I did it every time I removed the hpfp, even before I installed the stud kit.
    -Adam
    Oct 01 2014
    Audi Q5
    chicago,il
    Well actually I didn't move the hard pipe to get hpfp out. I was going to unscrew the hard when I'm going to install the IE pump. Just want to confirm you unscrew hard pipe. So now just wait till its warmer to do it.
    Feb 15 2016
    Cambridge,Ontario
    on a related note anyone want to post any pics of special tools they have fabbed or use for that banjo bolt ? I haven't done this job yet but sounds like it will be a semi regular thing to check so fabbbing a tool may be useful.
    im not even sure of the size , is it a 4mm triple square ?
    1976 Yamaha XS 360
    Oct 01 2014
    Audi Q5
    chicago,il
    Cam follower DIY PDF document
    It's 8mm triple square
    Mar 24 2013
    Oakdale, CT
    8mm triple square attached to 2 long 3/8" drive extensions. Guide it up from down by the axle on to the bolt. I did take a 17mm wrench and cut it to about 1.5" or so to use on the union on the HP side of the pump.
    -Adam
    Dec 23 2011
    I did something similar for the other fitting on the hpfp. Cut a 17mm wrench to half length which allows more room to tighten/loosen the nut.
